Temp gage acting weird
09-22-2006, 06:48 PM
OKay guys,
My temparature gage is acting up since yesterday. It just reads max from the moment I start the car but when I'm accelerating it suddenly reads the right temparature.
My radiator is nicely filled up with fluids so that's not it...
My guess would be that there's some air trapped and it's reading hot air and when I press the throttle fluids is washed against the sensor and its reading proper temp but I thought the system was designed to push out any trapped air?
Any ideas? Might just be the sensor is broken but I'd assume it would work at all then.. OR a broken wire but then I'd assume it just read 0 or right temp, not max...
09-22-2006, 06:51 PM
check your wiring...maybe your engine ground wire needs tightening or something like that.
09-22-2006, 08:30 PM
or clean up your tempsensor... it worked for about a year by my car
[Image: AEU86 AE86 - Temp gage acting weird]
  weird gearbox part2(possible trd set a) ditn 6 7,230 01-31-2016 08:01 PM
Last Post: totta Crolla
  AE86 Engine Coolant Temp Sensor izanagi 8 20,654 09-06-2014 05:47 PM
Last Post: izanagi
  T50 weird gear set What´s going on? fax0815 13 45,368 08-13-2012 04:50 PM
Last Post: Project D
  track questions:max oil/water temp,egt and other ditn 7 8,238 07-06-2012 12:40 PM
Last Post: ditn
  Oil Pressure - Kinda weird pack 12 21,331 05-31-2012 12:56 AM
Last Post: pack
