Temp gage acting weird
09-22-2006, 06:48 PM
OKay guys,
My temparature gage is acting up since yesterday. It just reads max from the moment I start the car but when I'm accelerating it suddenly reads the right temparature. My radiator is nicely filled up with fluids so that's not it... My guess would be that there's some air trapped and it's reading hot air and when I press the throttle fluids is washed against the sensor and its reading proper temp but I thought the system was designed to push out any trapped air? Any ideas? Might just be the sensor is broken but I'd assume it would work at all then.. OR a broken wire but then I'd assume it just read 0 or right temp, not max... Greetz, Bastiaan "mux213" Olij Moved down under, no more hachi ![]() |
09-22-2006, 06:51 PM
check your wiring...maybe your engine ground wire needs tightening or something like that.
09-22-2006, 08:30 PM
or clean up your tempsensor... it worked for about a year by my car
weird gearbox part2(possible trd set a) | ditn | 6 | 7,217 |
01-31-2016 08:01 PM Last Post: totta Crolla |
AE86 Engine Coolant Temp Sensor | izanagi | 8 | 20,605 |
09-06-2014 05:47 PM Last Post: izanagi |
T50 weird gear set What´s going on? | fax0815 | 13 | 45,240 |
08-13-2012 04:50 PM Last Post: Project D |
track questions:max oil/water temp,egt and other | ditn | 7 | 8,222 |
07-06-2012 12:40 PM Last Post: ditn |
Oil Pressure - Kinda weird | pack | 12 | 21,311 |
05-31-2012 12:56 AM Last Post: pack |
