Throttle question????????
08-18-2009, 03:59 PM
Is there a difference between the small port 4AGE FWD throttle and the big port 4AGE RWD? If so what is the difference? |
08-18-2009, 05:06 PM
They might be different in the way that they bolt on to 2 completely different inlet manifold types. Never seen a smallport one from close range so I couldnt say really.
08-18-2009, 05:34 PM
Reason why I'm asking is because my small port throttle is not working 100% at present and I need to fit the TVIS throttle for the mean time until the 20V ITB comes on
08-19-2009, 01:38 AM
there is a difference....... The bypass is on the opposite side when it comes to fwd T/B vs rwd T/B
Dan - You can | OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
08-19-2009, 10:32 AM
Thanx OST...I will make a way to amke it work on my FWD
08-25-2009, 05:34 PM
Hey guys,
We got it right to fit the back part of the throttle on my current throttle and it worked... Thanx for your input it's very much appreciated... |
| Video : Adjust the TPS (Throttle Pos Sensor) on the 4A-GE | Homem Bomba | 3 | 12,766 |
10-25-2013 05:13 PM Last Post: Apsogos |
| surgin when u throttle help | ae86 tn | 4 | 5,691 |
11-28-2009 03:00 AM Last Post: ae86 tn |
| throttle conversion | hygneji | 4 | 5,646 |
11-12-2009 10:18 AM Last Post: Ivan141 |
| AE101 throttle body on an AE86 what ECU? | megabob | 7 | 10,163 |
11-09-2009 09:12 AM Last Post: Ivan141 |
| 16v to 20v throttle body's TPS | lolali | 4 | 10,984 |
10-21-2009 01:04 PM Last Post: isac |
