Toyota rear caliper
01-25-2014, 11:54 AM
Toyota rear caliper
Does anyone know of a way to identify genuine Toyota rear brake calipers ?
(The hand brake pivot on genuine Toyota calipers runs in a needle roller bearing and this bearing is not fitted to pattern part calipers)
Is it as simple as Toyota ones say Toyota on them ? Blush
01-26-2014, 10:13 AM
Toyota rear caliper
Aftermarkets put a bronze bushing in the oem caliper.
Andrew
01-26-2014, 11:53 AM
Toyota rear caliper
Sorry Andrew I didn't really make the question very clear I should have asked if it is possible to tell the Toyota part from the outside without dismantling it ?
01-27-2014, 08:32 AM
Toyota rear caliper
Nope.
Andrew
01-27-2014, 12:01 PM
Toyota rear caliper
assassin10000 Wrote:Nope.
Andrew
lol, that's that then Smile
01-27-2014, 02:15 PM
Toyota rear caliper
How about to use toyodiy.com?
[Image: AEU86 AE86 - Toyota rear caliper]
http://www.toyodiy.com/parts/p_J_1985_TO..._4707.html
My car even older than I.
Dec. 1983 zenki Levin coupe AE85 swapped to 4age16v from ae92 and other needed stuff and RHD to LHD
Nov. 1985 kouki Trueno hatchback AE85, with 86s suspension, @3A + A42DL, RHD
02-02-2014, 10:41 PM
Toyota rear caliper
Post no.13 in this thread:
http://www.ae86irl.com/forum/showthread....er+bearing
02-02-2014, 11:19 PM
Toyota rear caliper
I wonder if that bearing could be retro fitted to a caliper with the bronze bush ?
The hand brake pivot rubber seal is also different on the repro calipers as it does not locate in the same way as the Toyota seal does and the Toyota seal will not fit into the recess on the repro caliper, not on my one anyway.
  Rear Caliper Rebuild mad.matt 16 17,707 01-19-2017 02:19 PM
Last Post: Project D
  Rebuild rear disc brakes toyota crown ms112 axle bozu 0 3,931 12-21-2016 09:37 PM
Last Post: bozu
  brake caliper/line fitting Eifelaner 9 12,860 04-15-2013 11:38 AM
Last Post: Eifelaner
  Rear ae86 rear discs & pad part numbers? J-86 4 6,185 11-30-2012 06:32 PM
Last Post: J-86
  max brake disc thickness ae86 caliper+heel and toe question ditn 26 27,790 10-02-2012 05:00 PM
Last Post: ditn
