Trim levels?
05-22-2009, 07:42 PM
Trim levels?
So i am going to write GT Twincam
![]() Thanks alot |
11-20-2012, 05:13 AM
Trim levels?
JDM Zenki with digidash, no power window, no power steering, ...is it GT Apex or GTV?
i saw a lot mentioned here the GT Apex has all the luxorious trims. getting confused. ![]() |
11-20-2012, 03:07 PM
Trim levels?
The easy way to tell if its gtapex or gtv is the rear cards..
If it has these wrap around parts it is gtapex ![]() ![]() If it has normal covers over the wheel arch it is gtv (this photo is ae85 but same rear as gtv) ![]() This is the same Zenki or Kouki, also apex usually has long built in arm rests on the front door cards while gtv has smaller screw in type I know new zealand model 86 used gtapex trim, same with UK too I think, I'm not sure about european market.. hope this helps ![]() slpery.wordpress.com |
11-20-2012, 03:15 PM
Trim levels?
Gtapex door cards
![]() Gtv door cards ![]() slpery.wordpress.com |
11-20-2012, 03:56 PM
Trim levels?
Some of the differences above are zenki-kouki differences, not spec differences per-se. For instance, I do believe every kouki car I have seen has the latter type of doorcard.
11-20-2012, 04:59 PM
Trim levels?
Oh, you are correct Ivan! Upon inspection it seems Kouki gtapex has longer arm rests but not moulded
11-20-2012, 09:24 PM
Trim levels?
Also the wraparound parts were standard on the EU GT models.
1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop: ![]() |
Removing front window trim | zenki | 7 | 12,834 |
09-07-2014 08:36 PM Last Post: Ivan141 |
ecu fuel trim | totta Crolla | 13 | 13,375 |
11-18-2012 09:36 PM Last Post: jondee86 |
Emissions test failed due to high CO2 levels in IDLE | heshan | 1 | 5,980 |
09-04-2012 08:00 PM Last Post: banpei |
AE86 Weather Stripping / Window Trim | juantonwan | 3 | 6,135 |
02-27-2010 07:11 PM Last Post: aussiefan |
Trim Problem | Serencebey | 5 | 5,600 |
03-16-2009 08:07 PM Last Post: Serencebey |
User(s) browsing this thread:
