Trim levels?
05-22-2009, 07:42 PM
Trim levels?
So i am going to write GT Twincam Smile
Thanks alot
11-20-2012, 05:13 AM
Trim levels?
JDM Zenki with digidash, no power window, no power steering, ...is it GT Apex or GTV?
i saw a lot mentioned here the GT Apex has all the luxorious trims. getting confused. Banging head
11-20-2012, 03:07 PM
Trim levels?
The easy way to tell if its gtapex or gtv is the rear cards..
If it has these wrap around parts it is gtapex
[Image: AEU86 AE86 - Trim levels?]
If it has normal covers over the wheel arch it is gtv (this photo is ae85 but same rear as gtv)
This is the same Zenki or Kouki, also apex usually has long built in arm rests on the front door cards while gtv has smaller screw in type
I know new zealand model 86 used gtapex trim, same with UK too I think, I'm not sure about european market.. hope this helps Smile
slpery.wordpress.com
11-20-2012, 03:15 PM
Trim levels?
Gtapex door cards
Gtv door cards
11-20-2012, 03:56 PM
Trim levels?
Some of the differences above are zenki-kouki differences, not spec differences per-se. For instance, I do believe every kouki car I have seen has the latter type of doorcard.
11-20-2012, 04:59 PM
Trim levels?
Oh, you are correct Ivan! Upon inspection it seems Kouki gtapex has longer arm rests but not moulded
11-20-2012, 09:24 PM
Trim levels?
Also the wraparound parts were standard on the EU GT models.
  Removing front window trim zenki 7 12,228 09-07-2014 08:36 PM
  ecu fuel trim totta Crolla 13 12,580 11-18-2012 09:36 PM
Last Post: jondee86
  Emissions test failed due to high CO2 levels in IDLE heshan 1 5,753 09-04-2012 08:00 PM
  AE86 Weather Stripping / Window Trim juantonwan 3 5,892 02-27-2010 07:11 PM
Last Post: aussiefan
  Trim Problem Serencebey 5 5,286 03-16-2009 08:07 PM
Last Post: Serencebey
User(s) browsing this thread: 13 Guest(s)
