Tuned 4AGE results
10-16-2009, 03:40 PM
Post: #41
Tuned 4AGE results
Here is one of my Gen 1 GZE
(AE92 I guess due to DLI and AFM (L-JET) 275K on the car and about 200K on engine.. Stock ECU, NO Intercooler (just a conection pipe) stock exhoust header rest is Megan Catback ![]() funny thing is that the power is still increasing until max RPM! and that I have so mutch horsepower! I should have 145HP and this is almost 165HP! what are your thoughts about it... Kind Regards, Roel [/img] Gtsi-R "Trust me, I was an engineer" "straight lines are for fast cars, turns are for fast drivers" |
10-16-2009, 03:51 PM
Post: #42
Tuned 4AGE results
Gtsi-R Wrote:Here is one of my Gen 1 GZE Nothing wrong there ![]() |
10-16-2009, 03:56 PM
Post: #43
Tuned 4AGE results
GTRJazz Wrote:But mine gets most use on track where I would never drop below 5k so a good benifit for me power is 131.9 bhp at only 6950rpm instead of 133bhp at 7650rpm so when the fueling issue is fixed I will make quite a bit more reving up to 8000rpm Its difficult to tell, but on the old graph you seem to have 130ish hp from below 700rpm as well.. Any reason the second run was to a lower RPM? Seems like you might have found more hp at 7600rpm again. A wheel to steer the front of the car A pedal to steer the rear |
10-16-2009, 04:43 PM
Post: #44
Tuned 4AGE results
NoHachi Wrote:GTRJazz Wrote:But mine gets most use on track where I would never drop below 5k so a good benifit for me power is 131.9 bhp at only 6950rpm instead of 133bhp at 7650rpm so when the fueling issue is fixed I will make quite a bit more reving up to 8000rpm Thats true, it ran lean at that point so we had to stop but do expect to see more bhp from 7000 rpm on. |
05-19-2013, 07:16 PM
Post: #45
Tuned 4AGE results
robokill Wrote: Apologies for the lateness in replying. Power was measured at the wheels but I read the result as engine HP calculated from whatever the wheels put out. http://www.skynet.ie/~eireae86 |
05-21-2013, 08:11 AM
Post: #46
Tuned 4AGE results
my setup:
ae86 4age bigport haltech e6x ecu ae101 itbs catcams 260° / 252° 9.00 / 8.50mm hks valve springs adjustable cam pulleys geo prizm vin 5 injectors made 112kw/153hp on flywheel ![]() http://nuudelbahn.wordpress.com/ http://www.superlapbattle.lu https://www.facebook.com/SLBRaceleague |
07-09-2013, 09:57 PM
Post: #47
Tuned 4AGE results
What cam timing will you recommend formy set up?
264° hks in and ex martelieus header 4-2-1 and muffler trd head gasket 0.8mm, shave 0.5 mm toda adjustable cams My 86 is a zenky model Thanks my toyota is fantastic |
07-10-2013, 03:07 AM
Post: #48
Tuned 4AGE results
Meaurements @ the wheels 145 whp and 112 #/ft of torque (back calculated to flywheel numbers 170hp & 134#/ft)
![]() Short and sweet AE92 smallport head - ported Web 577 camshafts, T3 timing pulleys set to 111 degrees AE92 high comp block w squiters plugged, decked, stock head gasket Euro TVIS pistons(10 to 1) final measure compression ratio of 10.75 to 1 AE86 "small" crank w 40mm rod journals, lightened, shotpeened, and balanced "3 rib bluetop type" AE86 small connecting rods - lightened, shotpeened and balanced wrist pins are aftermarket steel 64 grams vs 89 grams for stock blacktop flywheel w AE92 clutch crank pulley is OEM 2 row, machined and rebalanced as a single row KBD 4/2/1 header Brave 60mm exhaust FJO racing management sequential injection wasted spark ignition running on 92 octane fuel http://i79.photobucket.com/albums/j143/o...stdyno.jpg This is her first dyno run. The initial map was only written to 7500 rpm(engine and cams are good to 8500) 141whp @ 7468, 108#s wheel torque @ 6127rpm. Engine numbers(back calculated by their dyno) 164hp @7468, 128ft/# 6127rpm edited - 2nd dyno run now posted. System is still not final tuned, final tuning will take place after the engine has 1000 miles. Please note, there is over 90#/ft for more than 4500 rpm ..... and ALL emissions complaint!!! ![]() Dan - You can | ![]() OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
07-12-2013, 08:24 AM
Post: #49
Tuned 4AGE results
makkuro Wrote:What cam timing will you recommend formy set up? Now i know what timing i will use. but first i want to thank Project D who guided me all the way through ( choice of the cams, choice of the size of the gasket, choice of the muffler, how much to shave, how to break in the engine etc to get the number that i got. ![]() He convinced me to keep my engine and upgrade it as it is now instead of doing a swap where i will spend way more because you never know how is the health of the engine, real mileage, change the wires.etc. you know what i mean. thanks dude! here is my numbers: 148hp on not ultimate condition ![]() my toyota is fantastic |
07-12-2013, 11:15 AM
Post: #50
Tuned 4AGE results
If I can add few things up about makkuro's setup.
The engine head, apart from the parts mentioned earlier, is absolutely stock. (Not ported) Also, he still use the stock ECU 1st: 148hp (135rwhp) @ 7327rpm and 158Nm (116.6ft-lbs) @ 5294rpm 2nd: 146.2hp (133rwhp) @ 6868rpm and 163.3Nm (120.5ft-lbs) @ 5308rpm 3rd: 147.4hp (134rwhp) @ 7059rpm and 162Nm (119.5ft-lbs) @ 5191rpm |
Max a 16v 4AGE can be tuned to? | heshan | 20 | 57,481 |
04-21-2009 08:31 PM Last Post: banpei |
Silvertop burning oil - compression results | Jezza_hr | 3 | 4,950 |
10-18-2008 02:51 AM Last Post: jondee86 |
AE86 Dyno Results! | Wraith | 9 | 14,763 |
10-16-2006 09:13 AM Last Post: Mux213 |
User(s) browsing this thread:
