Turn signal problem
03-27-2005, 07:00 PM
Turn signal problem
I have a problem with turn signal on my hachi. As you know, I moved all electrical from GTS to SR5 chasis, and every thing work fine for some time.
Than, I Was cheking fuses, and chek every one, and they all are ok. Problem is that my hazad warning is working ( all 6 lights ) but, when I want to use only left, or right, they dosen't work. I have manual, and chek turn signal swich, work fine, chek relay on right side of car which is conected somehow to turn signal swich, becouse I heard in Zax's car when you use left or right side, he is working, just then. I chek turn signal flasher, work fine. Does anyone know solution of this problem? I dont have conecting diagram for this parts, so, if some one have this, it will be nice...... Please help 1984 AE 86 Levin hatchback 1989 AE 92 GTi 2004 Kawasaki KLE 500 CROATIA - small country for great drift |
03-27-2005, 10:20 PM
Turn signal problem
I've had the same problem a while ago. The fuse was wrong in my car, you might want to check them again?
SutteR |
03-28-2005, 01:11 PM
Turn signal problem
Problem solved. On board with fuses, one wire was damaged. When you use hazard warning light, they wok thru fuse of horn, and, when you use only left or right signal, they use turn signal fuse.
Start wont turn over after installing radio | MC_JP | 6 | 9,714 |
Toyota COPs tach signal | Jan Pedersen | 5 | 7,036 |
01-14-2014 02:49 PM Last Post: Jan Pedersen |
4agZe problem solved - 99% IC problem | Okami | 41 | 35,995 |
VSS signal from stock cluster ? | Uzelac | 7 | 9,877 |
12-13-2011 01:42 PM Last Post: Uzelac |
Digital Cluster temp and fuel wont turn on | KameleonK | 3 | 5,349 |
10-21-2010 01:37 PM Last Post: ilker_ae86 |
