URGENT: Need electric help, injectors not fireing
07-05-2011, 10:47 AM
Had the same problem while wiring a hachi a few days ago. Problem was the big black plug against the firewall that connects the dash harness to the engine harness. On the dash side there was a missing wire (+12V) that feeds all the injectors with power. It was the wire in the very center of the plug. (D- in the books.
Porblem was that the engine harness was Zenki and the dash harness was Kouki. On Kouki cars this inj feed is located near the battery. http://monkeymagic86.wordpress.com |
07-05-2011, 11:47 AM
Nomuken Wrote:Had the same problem while wiring a hachi a few days ago. Problem was the big black plug against the firewall that connects the dash harness to the engine harness. On the dash side there was a missing wire (+12V) that feeds all the injectors with power. It was the wire in the very center of the plug. (D- in the books. Yeah, we noticed that AE86 has 9 wires in the loom, while SR5 has 8. Our injectors had 12V, but still they were not fireing (no clicking sound whem cranking). Changing the loom you mentioned solved the problem. Drifting - best fun you can have in your car with your pants on! |
07-05-2011, 01:10 PM
Yeah, even with that wire missing my injectors also had 12V. By adding the one missing wire, everything worked
4AGE Injectors resistor | Blaze0010 | 4 | 395 |
01-27-2025 03:20 PM Last Post: Bean |
Need help identifying this! | takumi_mt | 4 | 1,133 |
TRD ECU need help | ps13michi | 5 | 4,146 |
Need some help | DJexor | 4 | 5,443 |
03-13-2018 05:37 PM Last Post: pack |
JDM trueno not starting. need help! | kazi | 8 | 8,958 |
