URGENT: Need electric help, injectors not fireing
07-05-2011, 10:47 AM
Had the same problem while wiring a hachi a few days ago. Problem was the big black plug against the firewall that connects the dash harness to the engine harness. On the dash side there was a missing wire (+12V) that feeds all the injectors with power. It was the wire in the very center of the plug. (D-Cool in the books.
Porblem was that the engine harness was Zenki and the dash harness was Kouki. On Kouki cars this inj feed is located near the battery.
http://monkeymagic86.wordpress.com
07-05-2011, 11:47 AM
Nomuken Wrote:Had the same problem while wiring a hachi a few days ago. Problem was the big black plug against the firewall that connects the dash harness to the engine harness. On the dash side there was a missing wire (+12V) that feeds all the injectors with power. It was the wire in the very center of the plug. (D-Cool in the books.
Yeah, we noticed that AE86 has 9 wires in the loom, while SR5 has 8.
Our injectors had 12V, but still they were not fireing (no clicking sound whem cranking).
Changing the loom you mentioned solved the problem.
07-05-2011, 01:10 PM
Yeah, even with that wire missing my injectors also had 12V. By adding the one missing wire, everything worked
  4AGE Injectors resistor Blaze0010 4 394 01-27-2025 03:20 PM
  Need help identifying this! takumi_mt 4 1,133 04-05-2024 09:17 AM
Last Post: takumi_mt
  TRD ECU need help ps13michi 5 4,146 02-18-2022 10:42 AM
Last Post: ps13michi
  Need some help DJexor 4 5,443 03-13-2018 05:37 PM
Last Post: pack
  JDM trueno not starting. need help! kazi 8 8,958 03-12-2017 05:05 PM
Last Post: kazi
