Upgrade Brake Master Cylinder
04-07-2006, 11:32 AM
Hi,
One more technical question... I think the hachi's braking power isn't very good (20 years of development since 1985). Anyone ever changed the OEM brake master cylinder for one with bigger piston diameter? It's worthless? What's the best to fit? Thks |
04-07-2006, 01:23 PM
Hey mate,
I've been thinking about that aswell. I know a mate of mine changed the BMC on his DeLorean for a double membrame one effectively doubling the effectiveness and it made a BIG difference. Then again on the DeLorean the front brakes are way to small to stop that big heavy monster so the extra force you can excert on the brakes helps. I have no idea what BMC we could use though... Greetz, Bastiaan "mux213" Olij Moved down under, no more hachi ![]() |
04-07-2006, 02:09 PM
Try AE82 one.
04-07-2006, 02:21 PM
jamie,
Is it bigger capacity ? Greetz, Bastiaan "mux213" Olij Moved down under, no more hachi ![]() |
04-07-2006, 02:23 PM
Mux213 Wrote:jamie, I have one - 1" bore (vs 3/4 of AE86 one) but a little shorter. I didn't calculated the capacity. |
04-07-2006, 02:27 PM
Will it fit in the place of a hachi's brake cylinder? I'm sure the brake lines would have to be changed a bit but if it will fit normally then it shouldn't be to much work to try.
Strange that an AE82 needed a bigger brake cylinder.. Greetz, Bastiaan "mux213" Olij Moved down under, no more hachi ![]() |
04-07-2006, 02:29 PM
What about ae92? Is it bigger?
04-07-2006, 02:35 PM
Mux213 Wrote:Will it fit in the place of a hachi's brake cylinder? I'm sure the brake lines would have to be changed a bit but if it will fit normally then it shouldn't be to much work to try. The pattern seems the same, the car was AE82 1.6 4A engine (not 4AGE). |
04-07-2006, 02:37 PM
Time to visit the junkyard with my spare ae86 MBC, then start looking for something bigger with the same pattern
04-07-2006, 04:52 PM
I don't know if in the Toyota Repair Manuals refer the BMC diameter...
It would be a great help... |
4AGE cylinder head plug removal | Ivan141 | 5 | 2,207 |
Brake advice - master cylinder | mannix20vt | 12 | 14,452 |
Radiator oem or upgrade on racecar? | Jimmi The Kid | 5 | 5,922 |
06-23-2017 05:21 PM Last Post: pack |
Ta60 carina steering upgrade? | Allexz | 15 | 15,854 |
06-01-2016 08:12 AM Last Post: Allexz |
Correct connection brake master cylinder? | bozu | 5 | 7,440 |
