Velocity stacks = more power, now which to get?
02-21-2012, 08:41 PM
Post: #31
do you mean the original flexibel stacks? i have 2 sets of them. pm me if you are interested
02-21-2012, 08:58 PM
Post: #32
slowboy2 Wrote:do you mean the original flexibel stacks? i have 2 sets of them. pm me if you are interested
NO, I ment some aloy aftermarked :wink:
Project AE86 now begun.
Cars I have owned:
Toyota Starlet EP91 1,3 16v Turbo, 200hp
Toyota Starlet EP71 1,3 12v Sport
Mercedes 207D camper, 1977.
Toyota Starlet EP70 with a 174hp Silvertop 20v See video here:
http://videos.streetfire.net/search/Star...079edc.htm
Toyota Corolla AE101 with a 164hp Silvertop 20v. (Evolution bodykit and candycolor paint).
Volvo 240 2,1 (The only car I have maked money on).
Toyota Corolla EE90 (my first car)
02-21-2012, 09:10 PM
Post: #33
well if you got the stock ones you could measure the centerline, then you have it Wink assuming the stacks are the only thing you change... although I can't see any sense in that as the OEM system is perfect for stock setup.
02-21-2012, 09:18 PM
Post: #34
The stock ones are not stacks, they are noise killers :wink:
Cars I have owned:
02-21-2012, 09:25 PM
Post: #35
Jimmi The Kid Wrote:The stock ones are not stacks, they are noise killers :wink:
Banging head if you plan to remove the airbox and run pimp, flashy stacks - my 2p are don't! You'll just ruin a very close to perfect setup. As long as you don't change anything else on tge OEM setup apart from filter and exhaust you can't do a better job than toyotas engineers did. The only thing you'll achieve is some props of silly youngsters and loss of power in the whole revrange.
But each to his own - like I said, just measure your stock ones and you got what you are looking for even if it's pointless in my oppinion.
02-21-2012, 10:20 PM
Post: #36
Well, my old 20v got 5-8hp just fitting some open stacks, but it sound like it get 200hp more Hurray!
Cars I have owned:
02-21-2012, 11:07 PM
Post: #37
Really, what you want to find out is the proper wave tuning of the 20v setup. This is called pulse tuning. It's reflective pulses generated as the valves open and close throughout the each cycle.
Custom stacks won't be cheap though but proper pulse tuning will net you performance. Pulse tuning also applies to the exhaust side of the motor as well.
Anyway, I just use an Induction Wave "Calculator" that I put together in .xls to make things easier on me.
[Image: AEU86 AE86 - Velocity stacks = more powe...ch to get?]
"Strictly All Things 86"
02-22-2012, 01:19 AM
Post: #38
Jimmi The Kid Wrote:Well, my old 20v got 5-8hp just fitting some open stacks, but it sound like it get 200hp more Hurray!
This ^^^ is a typical result obtained by removing the factory inlet plenum
and "bent" rubber intake stacks. And under cross-examination, the owner
will usually break down and admit that the gain was in the 6000-8000 rpm
range Thumbs up! Further questioning will also usually discover that there was a
loss of bottom end torque, making an already weak bottom end, worse Confused
Short stacks are the best for producing more top end... they also do the
most damage at lower rpm's. Longer stacks, such as the 110mm made by
TODA can give more performance all round, but are pricey !!! Even so,
as pointed out above, the best results can only be expected when the
stack is "tuned" to the engine mods, and the rpm range where the engine
needs to do its best work.
But yeah... the +200hp effect has gotta be worth something Cool
Cheers... jondee86
  20v BT - which oil pump? Mylesmck 4 2,833 06-21-2022 04:51 PM
Last Post: pack
  Rim width. Which is best.... Dino86 5 6,815 01-07-2017 03:09 PM
Last Post: Dino86
  which connector is this ditn 7 7,707 07-27-2015 11:24 AM
Last Post: pack
  Haslbeck front spoiler, which foglights? wouter86 2 5,089 02-15-2015 11:14 AM
Last Post: ditn
  which piston is this? ditn 10 12,132 07-04-2014 03:18 PM
