What brakes are you using ?
06-24-2005, 11:57 AM
Denmark Wrote:Oh ,
Do you know how big the center hole is on the OE disc?
Skassa
64mm.
This was the reason that I retired nice BMW 280mm discs - they had 74mm central bore and if I redrill them to 4X85 - they may break :-(
06-24-2005, 12:59 PM
dunno what everyone whines about but i run
brembo standard brake discs all around with lucas pads. I can block my wheels en my pedal is hard as a rock
06-24-2005, 01:12 PM
Thank you very much,
Do you make the centerhole to fit exact or do you just rely on the bolts to center the disc?
Regards,
Skassa
"""www.turbotoys.dk"""
06-24-2005, 02:04 PM
Denmark Wrote:Thank you very much,
Regards,
Skassa
You can rely on bolts but I always use hubcentric parts. If you try to use for example brake discs with 66mm center bore, buy or make inserts 66-->64mm (often you can buy platic ones in rims/tires centre/store). You can use plastic inserts - no problem - they are neccessary only to center the disc while you tight the screws (in fact front hub design of AE86 is not so hubcentric sensitive).
06-24-2005, 04:55 PM
hopefully I'll get my T3 big brake kit in the next 2 weeks....
06-25-2005, 01:01 AM
I got a pair of 4-pot FC calipers if someone wants to buy them.
Broken down 1984 Trueno HB
[Image: AEU86 AE86 - What brakes are you using ?]
06-25-2005, 02:01 AM
I think cheap brake discs with big mark like brembo or bradi for around 100$ for all 4 are fakes for sure. A lot of guys here are talking about it right now on forums. They are selling fake brembo brake discs in big car part markets here too Angry
I think they are making the holes and slots to the classic blank rotors and than they are selling them cheap.
One guy as i saw was talking on our forums that he ordered directly from brembo front discs and one costed him around 50 euro, classic blank.
85' AE86 GT coupe lifetime project since 2005
06-25-2005, 08:07 AM
ryo i run really brembo discs not slotted just standard vented they where retail 300 euro's everything
06-25-2005, 09:39 AM
I have to do some work on my front suspension soon which means a bit of s strip down of the front end. I have the mazda FC 4pots on the front of mine and its a very cheap way to upgrade the braking power of your car.
I will think on and get the brackets that hold the calipers onto the struts measured up. That way it will be easy for people to make copies.
Regards Ian.
06-25-2005, 11:44 AM
As i search in Japan i see adaptors for mazda brakes, but also EG6 ones so maybe that's another option
  Rear brakes totta Crolla 0 916 02-03-2023 12:54 PM
Last Post: totta Crolla
  Switching diffs for disc brakes? trippin 6 2,623 07-08-2022 03:35 AM
Last Post: trippin
  What suspension set up are people using? kazi 8 8,076 07-06-2017 05:26 AM
Last Post: headrush
  Rebuild rear disc brakes toyota crown ms112 axle bozu 0 3,771 12-21-2016 09:37 PM
Last Post: bozu
  Using a different diff in an AE86 megabob 6 8,288 02-17-2015 03:37 PM
Last Post: megabob
User(s) browsing this thread: 27 Guest(s)
