What brakes are you using ?
06-24-2005, 11:57 AM
Denmark Wrote:Oh ,64mm. This was the reason that I retired nice BMW 280mm discs - they had 74mm central bore and if I redrill them to 4X85 - they may break :-( |
06-24-2005, 12:59 PM
dunno what everyone whines about but i run
brembo standard brake discs all around with lucas pads. I can block my wheels en my pedal is hard as a rock Cars: "99 Lexus IS200 "86 AE86 Kouki Panda Levin GT-Apex (restore project) "84 AE86 Zenki Blue Levin (project racer) Motorcycles: "02 Yamaha R1 "02 Honda Hornet S "08 BMW R1200GS |
06-24-2005, 01:12 PM
Thank you very much,
Do you make the centerhole to fit exact or do you just rely on the bolts to center the disc? Regards, Skassa Any fool can go fast in a straight line. VEMS Blacktop 4AGTE20V 272hp/350nm """www.turbotoys.dk""" |
06-24-2005, 02:04 PM
Denmark Wrote:Thank you very much, You can rely on bolts but I always use hubcentric parts. If you try to use for example brake discs with 66mm center bore, buy or make inserts 66-->64mm (often you can buy platic ones in rims/tires centre/store). You can use plastic inserts - no problem - they are neccessary only to center the disc while you tight the screws (in fact front hub design of AE86 is not so hubcentric sensitive). |
06-24-2005, 04:55 PM
hopefully I'll get my T3 big brake kit in the next 2 weeks....
06-25-2005, 01:01 AM
I got a pair of 4-pot FC calipers if someone wants to buy them.
Broken down 1984 Trueno HB |
06-25-2005, 02:01 AM
I think cheap brake discs with big mark like brembo or bradi for around 100$ for all 4 are fakes for sure. A lot of guys here are talking about it right now on forums. They are selling fake brembo brake discs in big car part markets here too
I think they are making the holes and slots to the classic blank rotors and than they are selling them cheap. One guy as i saw was talking on our forums that he ordered directly from brembo front discs and one costed him around 50 euro, classic blank. 85' AE86 GT coupe lifetime project since 2005 |
06-25-2005, 08:07 AM
ryo i run really brembo discs not slotted just standard vented they where retail 300 euro's everything
06-25-2005, 09:39 AM
I have to do some work on my front suspension soon which means a bit of s strip down of the front end. I have the mazda FC 4pots on the front of mine and its a very cheap way to upgrade the braking power of your car.
I will think on and get the brackets that hold the calipers onto the struts measured up. That way it will be easy for people to make copies. Regards Ian. |
06-25-2005, 11:44 AM
As i search in Japan i see adaptors for mazda brakes, but also EG6 ones so maybe that's another option
Rear brakes | totta Crolla | 0 | 916 |
02-03-2023 12:54 PM Last Post: totta Crolla |
Switching diffs for disc brakes? | trippin | 6 | 2,623 |
07-08-2022 03:35 AM Last Post: trippin |
What suspension set up are people using? | kazi | 8 | 8,076 |
07-06-2017 05:26 AM Last Post: headrush |
Rebuild rear disc brakes toyota crown ms112 axle | bozu | 0 | 3,771 |
Using a different diff in an AE86 | megabob | 6 | 8,288 |
02-17-2015 03:37 PM Last Post: megabob |
User(s) browsing this thread: 18 Guest(s)
