What rear diff to go with an engine upgrade?
05-20-2009, 01:05 AM
Hmmmmmmm, I have a different concern then NoHachi.
The pinion gear uses a crush collar to maintain pressure on the pinion bearing. The crush collar can and does fail when high torque loads are run through the ring and pinion. The "fix", or repair for this is called a solid pinion spacer. This is a collar that is NOT crushable, but it is made to an exacting spec and shim able. This soild pinion spacer will allow you to add a preload to the pinion bearing, while not using a crushable collar Dan - You can | .... OR you can ask for help!!! OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
Messages In This Thread |
What rear diff to go with an engine upgrade? - Snejk - 05-15-2009, 11:18 PM
[] - oldeskewltoy - 05-20-2009 01:05 AM
[] - oldeskewltoy - 05-21-2009, 10:02 AM
Radiator oem or upgrade on racecar? | Jimmi The Kid | 5 | 5,656 |
Ta60 carina steering upgrade? | Allexz | 15 | 15,134 |
06-01-2016 08:12 AM Last Post: Allexz |
toyota a series engine....can a fwd corolla engine be used | 210 datsun guy | 5 | 8,068 |
Weir Performance rear upgrade kit for AE86 | heshan | 5 | 9,032 |
07-22-2013 09:11 PM Last Post: heshan |
Rear ae86 rear discs & pad part numbers? | J-86 | 4 | 5,827 |
