Where to find the informations on the gearbox/engine
02-07-2009, 11:02 PM
If you ask me that does not look like a T series at all: not square and its got only two ribs.
It looks like the W55/58/59 which does only have two ribs:
http://www.customtacos.com/forum/showthr...p?t=121942
I know Toyota installed some W59s in trucks, so perhaps that's where the gearbox came from. Smile
[Image: AEU86 AE86 - Where to find the informati...box/engine]
02-07-2009, 11:06 PM
thanks for the precision.
The engine on it is a diesel, 2C.
So if i swap, i have to find a gearbox also Crying
02-07-2009, 11:30 PM
Not entirely true: a W55/56/57/58/59 gearbox should be compatible in its bellhousings, so if you want to drop in a 4AGE you can buy a 4A->W58 bellhousing and swap that for the 1C/2C bellhousing on your W59.
There are several sources for that bellhousing, but most of them are unfortunately located in Australia:
http://www.ajps.com.au/parts/w5x_bellhousing.asp
02-07-2009, 11:34 PM
banpei Wrote:Not entirely true: a W55/56/57/58/59 gearbox should be compatible in its bellhousings, so if you want to drop in a 4AGE you can buy a 4A->W58 bellhousing and swap that for the 1C/2C bellhousing on your W59.
you lost me on the way Wave , come back Big Grin Big Grin
i am used to Toyota logic yet. Honda is more simple Big Grin
i am planning more on a 3SGTE, but a 4A can be good to start Wave
02-08-2009, 10:33 PM
Well, it isn't entirely Toyota logic since Toyota isn't the manufacturer of those boxes. But basically what happens is that the gearbox is a loose component and the engine needs to be fitted to that. That's why there are different bellhousings which fit on certain gearboxes.
In case of the W series there are two generations of W gearboxes. The new series start at W55 and the bellhousings are not compatible with older series.
As stated before: the 3S fits on the 1C bellhousing. If you currently have a 2C engine fitting on the W59 gearbox it should fit the 3S engine since the 2C should have the same block as the 1C. I also see several resource around the world saying the 1C and 2C both fit.
Personally I would go for the 3SGTE. If you would put a 4AGE in there you only would be disappointed in the amount of time, money and effort you put into it and having less torque than the 2C diesel had.
02-12-2009, 06:26 PM
banpei
Thanks for your reply Thumbs up!
I have to find out if the gearbox is really what it seams.
For the moment, the only engine i found in Malta is a 3SFE which might be the first step to go, or i will go for a complete MR2 in UK for swap.
Do you know if maybe some parts of the MR2 (chassis) would fit the TE ?
What is strange for me, it is not to find some special engine mount done especially for swap, like there are for Honda Sad
04-10-2009, 07:49 PM
Hi
I took off this bloody gearbox and i cannot find the number on it. I do not know what gearbox it is Angry
  Emergency help find store with bearings france Allexz 5 4,715 09-12-2019 03:24 PM
Last Post: Allexz
  ford type 9 gearbox with 4age engine filh 29 48,694 01-11-2015 01:02 PM
Last Post: filh
  toyota a series engine....can a fwd corolla engine be used 210 datsun guy 5 8,172 10-30-2013 11:18 PM
  Were to find 4AG-ZE gaskets in toyota diy? fax0815 17 15,815 05-28-2013 10:17 PM
Last Post: ditn
  Question: Where I can find this fender flare? winchi.c 3 5,259 05-01-2011 09:58 AM
Last Post: Bentley
