Which head do I have - On the car, not me!
02-06-2007, 11:51 PM
I am thinking of getting a inlet manifold made for either Motorbike Carb's or throttle bodies, but just wondering what head type I have, so I can get an inlet manifold gasket. I have a 4age with TVIS, but whick type, small, large port etc, Is there a marking on the head or inlet.
Thanks
Ivan
1972 MG Midget - AE86 Engine, Ford Anglia Axle - Escort LSD - Live the Dream!!1
02-06-2007, 11:52 PM
TVIS=bigport head.
65mm wide ports - just measure. Small ports are 50mm wide.
02-07-2007, 12:01 AM
What measurement do you mean? The actual throttle body itself.
http://www.aeu86.org/viewtopic.php?t=270...=mg+midget
Here is a link with a pic attached.
hope this helps
Cheers
Ivan
02-07-2007, 12:25 AM
http://www.billzilla.org/4agstock.htm
[Image: AEU86 AE86 - Which head do I have - On the car, not me!]
I mean dimensions of intake port in the head.
PS: I can deliver intake adapter for bigport head to sidedraught Weber/Delorto/Solex pattern (check my thread in Commersial Sales section - if pictures don't work I can send via e-mail).
02-07-2007, 12:57 AM
jamie i have one question on you, the diffrence between carbs flanges
solex vs weber.
i have addhe and my friend one weber i am not sure about type, they have identical hole diameters and positions but the mounting points dont match.
02-07-2007, 12:59 AM
is there any way of telling without taking the inlet manifold off the car?
Cheers
Ivan
02-07-2007, 01:17 AM
If you are sure it´s an TVIS, then there is no doubt.....you´ll need the bigport gasket.
Look between the manifold and head, is there a plate about 2cm thick? If so, it´s most likely a TVIS engine/bigport.
Also look at the inlet manifold, if it´s "clean" on top without "ribbles" then it´s a TVIS/bigport manifold.
All of this of course, is with respect to the fact that an adapter plate from bigport-manifold to small port head can be installed previously, allthough very unlikely.
Make sense?
My evil Red/Black Panda
My current JDM AE86 project
02-07-2007, 01:19 AM
just had a look at you´re engine bay shot.....you have a TVIS/Bigport engine.
But to be 100% sure no-one has installed the smallport top to the largeport manifold.....you´ll need to remove the inlet manifold.
02-07-2007, 01:39 AM
the engine in midget is bigport
02-07-2007, 02:00 AM
thanks guys,
Have to decide now whether to go for carbs or throttle bodies. The carbs are working out alot cheaper. decisions, decisions!!
Cheers
Ivan
  20v BT - which oil pump? Mylesmck 4 2,631 06-21-2022 04:51 PM
Last Post: pack
  Rim width. Which is best.... Dino86 5 6,708 01-07-2017 03:09 PM
Last Post: Dino86
  which connector is this ditn 7 7,571 07-27-2015 11:24 AM
Last Post: pack
  How would/have you rebuild your 4age? joaotcgt 6 8,895 07-21-2015 10:40 AM
  Haslbeck front spoiler, which foglights? wouter86 2 4,991 02-15-2015 11:14 AM
Last Post: ditn
