Which head do I have - On the car, not me!
02-06-2007, 11:51 PM
I am thinking of getting a inlet manifold made for either Motorbike Carb's or throttle bodies, but just wondering what head type I have, so I can get an inlet manifold gasket. I have a 4age with TVIS, but whick type, small, large port etc, Is there a marking on the head or inlet.
Thanks Ivan 1972 MG Midget - AE86 Engine, Ford Anglia Axle - Escort LSD - Live the Dream!!1 |
02-06-2007, 11:52 PM
TVIS=bigport head.
65mm wide ports - just measure. Small ports are 50mm wide. |
02-07-2007, 12:01 AM
What measurement do you mean? The actual throttle body itself.
http://www.aeu86.org/viewtopic.php?t=270...=mg+midget Here is a link with a pic attached. hope this helps Cheers Ivan 1972 MG Midget - AE86 Engine, Ford Anglia Axle - Escort LSD - Live the Dream!!1 |
02-07-2007, 12:25 AM
http://www.billzilla.org/4agstock.htm
I mean dimensions of intake port in the head. PS: I can deliver intake adapter for bigport head to sidedraught Weber/Delorto/Solex pattern (check my thread in Commersial Sales section - if pictures don't work I can send via e-mail). |
02-07-2007, 12:57 AM
jamie i have one question on you, the diffrence between carbs flanges
solex vs weber. i have addhe and my friend one weber i am not sure about type, they have identical hole diameters and positions but the mounting points dont match. |
02-07-2007, 12:59 AM
is there any way of telling without taking the inlet manifold off the car?
02-07-2007, 01:17 AM
If you are sure it´s an TVIS, then there is no doubt.....you´ll need the bigport gasket.
Look between the manifold and head, is there a plate about 2cm thick? If so, it´s most likely a TVIS engine/bigport. Also look at the inlet manifold, if it´s "clean" on top without "ribbles" then it´s a TVIS/bigport manifold. All of this of course, is with respect to the fact that an adapter plate from bigport-manifold to small port head can be installed previously, allthough very unlikely. Make sense? My evil Red/Black Panda http://www.bilgalleri.dk/html/gal_visbil.asp?ID=12832 My current JDM AE86 project http://www.bilgalleri.dk/html/gal_visbil.asp?ID=31609 |
02-07-2007, 01:19 AM
just had a look at you´re engine bay shot.....you have a TVIS/Bigport engine.
But to be 100% sure no-one has installed the smallport top to the largeport manifold.....you´ll need to remove the inlet manifold. My evil Red/Black Panda http://www.bilgalleri.dk/html/gal_visbil.asp?ID=12832 My current JDM AE86 project http://www.bilgalleri.dk/html/gal_visbil.asp?ID=31609 |
02-07-2007, 01:39 AM
the engine in midget is bigport
02-07-2007, 02:00 AM
thanks guys,
Have to decide now whether to go for carbs or throttle bodies. The carbs are working out alot cheaper. decisions, decisions!! Cheers Ivan 1972 MG Midget - AE86 Engine, Ford Anglia Axle - Escort LSD - Live the Dream!!1 |
20v BT - which oil pump? | Mylesmck | 4 | 2,627 |
Rim width. Which is best.... | Dino86 | 5 | 6,707 |
which connector is this | ditn | 7 | 7,563 |
07-27-2015 11:24 AM Last Post: pack |
How would/have you rebuild your 4age? | joaotcgt | 6 | 8,894 |
07-21-2015 10:40 AM Last Post: mad.matt |
Haslbeck front spoiler, which foglights? | wouter86 | 2 | 4,990 |
02-15-2015 11:14 AM Last Post: ditn |
