about 5mm TRD headgasket
04-07-2007, 03:35 PM
My portuguese friends, what do you suggest for my engine?
I'm thinking in the same setup as André... Is it enough or can i go a little bit further?
Thanks
04-13-2007, 01:07 PM
if you want to keep the standard ecu and save yourself a lot of work .... go to apardal setup .....
don't forget to shave the head a good bit, because the cams make you loose torque .....
04-13-2007, 07:03 PM
Yes a greater timing will lose torque down low, but what about increassing the lift? Because 7.5 mm lift isn't much even for a stock engine.. i think there's alot of potential to be unlocked.. or am i wrong?
Im very curious about this thing. Increasing compression sure increases your torque; but the question is, wouldnt you gain more with higher lift cams, than with shaving your head?? (given that you want to play on the safe side, and keep the non-interferance) what is better?
04-13-2007, 08:25 PM
Apolan, increasing static CR is necessary when using higher duration cams (resulting CR is lower than with "stock" duration cams).
Higher lift is always better option for street (IMHO).
  Silvertop Headgasket? byd1380 3 4,230 01-05-2009 06:02 PM
Last Post: byd1380
  9.5mm lift camshafts with OEM followers... anyone? apardal 9 9,436 10-15-2008 03:24 PM
Last Post: robokill
  head skiming/size headgasket/hks f-con! nick 9 8,731 04-10-2008 06:17 PM
  will the 0.5 mm HEADGASKET clear? Apolan 15 13,745 01-31-2008 01:48 PM
Last Post: meshin
  5mm headgasket filh 14 11,814 01-28-2007 08:29 AM
Last Post: Plex
