01-23-2012, 09:16 PM
Hey man,
What brand is that rear diffuser?
Looking really good.
01-24-2012, 02:49 AM
mercury diffuser
1976 TA28 CELICA
1978 PUBLICA PICKUP
1980 4WD PICKUP
1983 AE86 LEVIN
2007 AYGO
01-24-2012, 04:04 PM
bakonick Wrote:in the 15x8 i have 205 45 15 toyo r888 andf in the 15x9 i have 225 45 15 also toyo r888
205/45/15 must be new tyre size release? which is good news as all along they only list 205/50 which is too big, are you having trouble with these hitting the body on full lock?
Also what thickness are your RCAs! biggest i have seen for sure!
surprised you did not have to lower the subframe to fit beams?
Thanks
Maurice
01-24-2012, 06:22 PM
i dont have problem with tyres becose the front wheels are 0 offset and i have also alloy hubs from http://www.grp4fabrications.com and they are 10mm wider to its side .
the rca are 45 mm from mcnsport .
as for the engine i took trd engine mounts from fensport for the beams
and i direct bold on them to the subframe .
1976 TA28 CELICA
1978 PUBLICA PICKUP
1980 4WD PICKUP
1983 AE86 LEVIN
2007 AYGO
01-24-2012, 07:50 PM
bakonick Wrote:i have also alloy hubs from http://www.grp4fabrications.com and they are 10mm wider to its side .
Oh right 10mm extra! i was looking at them alright should be a lot lighter than the original hubs which should help handling. well done nice spec everything you have will improve the car.
Just noticed you got the nagisa auto equal length boxes very nice! it will be a nice car to handle with that spec for sure
01-24-2012, 09:36 PM
you are welcome .
and yes they are a lot lighter than original ones.
1976 TA28 CELICA
1978 PUBLICA PICKUP
1980 4WD PICKUP
1983 AE86 LEVIN
2007 AYGO
01-24-2012, 11:48 PM
Have you measured the weight difference between the Gp4 and OEM hubs?
Nice car!
01-24-2012, 11:51 PM
you got me there ....
nop
1976 TA28 CELICA
1978 PUBLICA PICKUP
1980 4WD PICKUP
1983 AE86 LEVIN
2007 AYGO
01-27-2012, 12:21 AM
I can't find 205/45/15s on Toyo's site is this a EU thing only?
01-27-2012, 07:30 AM
They are special order.
  Racecar: TRD USA built ITA AE86 oldeskewltoy 38 44,063 07-22-2019 02:55 PM
Last Post: apardal
  Krullibulls Ae86 BEAMS is the only way krullibull 86 90,898 05-07-2019 09:35 PM
  Aram's 3SGE Beams Levin Coupe robokill 665 746,413 09-03-2017 09:24 PM
  AE86 GTV-Multipoint Cage, Beams, AP Brakes & Brides Conrad 462 616,786 06-27-2017 12:21 PM
Last Post: DJexor
  S.K.s AE86 racecar S.K. 207 226,644 09-18-2016 11:39 AM
Last Post: totta Crolla
