01-23-2012, 09:16 PM
Hey man,
What brand is that rear diffuser? Looking really good. |
01-24-2012, 02:49 AM
mercury diffuser
1976 TA28 CELICA 1978 PUBLICA PICKUP 1980 4WD PICKUP 1983 AE86 LEVIN 2007 AYGO |
01-24-2012, 04:04 PM
bakonick Wrote:in the 15x8 i have 205 45 15 toyo r888 andf in the 15x9 i have 225 45 15 also toyo r888 205/45/15 must be new tyre size release? which is good news as all along they only list 205/50 which is too big, are you having trouble with these hitting the body on full lock? Also what thickness are your RCAs! biggest i have seen for sure! surprised you did not have to lower the subframe to fit beams? Thanks Maurice |
01-24-2012, 06:22 PM
i dont have problem with tyres becose the front wheels are 0 offset and i have also alloy hubs from http://www.grp4fabrications.com and they are 10mm wider to its side .
the rca are 45 mm from mcnsport . as for the engine i took trd engine mounts from fensport for the beams and i direct bold on them to the subframe . 1976 TA28 CELICA 1978 PUBLICA PICKUP 1980 4WD PICKUP 1983 AE86 LEVIN 2007 AYGO |
01-24-2012, 07:50 PM
bakonick Wrote:i have also alloy hubs from http://www.grp4fabrications.com and they are 10mm wider to its side . Oh right 10mm extra! i was looking at them alright should be a lot lighter than the original hubs which should help handling. well done nice spec everything you have will improve the car. Just noticed you got the nagisa auto equal length boxes very nice! it will be a nice car to handle with that spec for sure |
01-24-2012, 09:36 PM
you are welcome .
and yes they are a lot lighter than original ones. 1976 TA28 CELICA 1978 PUBLICA PICKUP 1980 4WD PICKUP 1983 AE86 LEVIN 2007 AYGO |
01-24-2012, 11:48 PM
Have you measured the weight difference between the Gp4 and OEM hubs?
Nice car! A wheel to steer the front of the car A pedal to steer the rear |
01-24-2012, 11:51 PM
you got me there ....
nop 1976 TA28 CELICA 1978 PUBLICA PICKUP 1980 4WD PICKUP 1983 AE86 LEVIN 2007 AYGO |
01-27-2012, 12:21 AM
I can't find 205/45/15s on Toyo's site is this a EU thing only?
01-27-2012, 07:30 AM
They are special order.
Racecar: TRD USA built ITA AE86 | oldeskewltoy | 38 | 42,139 |
07-22-2019 02:55 PM Last Post: apardal |
Krullibulls Ae86 BEAMS is the only way | krullibull | 86 | 87,719 |
Aram's 3SGE Beams Levin Coupe | robokill | 665 | 725,994 |
AE86 GTV-Multipoint Cage, Beams, AP Brakes & Brides | Conrad | 462 | 603,474 |
S.K.s AE86 racecar | S.K. | 207 | 220,161 |
09-18-2016 11:39 AM Last Post: totta Crolla |
