bad coolant
11-14-2013, 08:53 AM
bad coolant
[Image: AEU86 AE86 - bad coolant]
I found my coolant is contaminated. Is it very bad for this condition?
The contaminant in the reservoir is difficult to clean off, I can't imagine how could I clean it off the whole radiator and engine...
Is this problem common in 4AG?
I am planning to flush the coolant system for a few times to see if the problem could be reliefed. Any suggestion?
11-14-2013, 11:50 AM
bad coolant
Looks fairly normal for a old engine and cooling system.
To thoroughly Flush the system through you can take out the radiator and flush it separately.
Personally I would fill the system with water and run it like that for a few days and flush it all again, finally filling with the right grade of coolant.
Don't forget to open the heater valve to 'hot' before flushing and refilling.
11-14-2013, 12:02 PM
bad coolant
Had that before, there seems to be a problem with 4AGEĀ“s und blue coolant.
Make sure you buy the right pink coolant!
1979 Toyota Corolla KE35
1983 Toyota Corolla AE86
1985 Toyota Corolla AE86
11-14-2013, 02:09 PM
bad coolant
Use pink or green collant in an 4AGE not the blue, as said above before.
Daily Beater: Civic EG5
Work in progress Car: AE86
11-14-2013, 05:37 PM
bad coolant
d3nso Wrote:Use pink or green collant in an 4AGE not the blue, as said above before.
Used green after blue, that fucked everyting up, my rebuild engine looked like a 200000miles no service engine with loads off clear gunk, went pink and never had any problems again.
11-15-2013, 04:07 AM
bad coolant
I flushed the cooling system last night:
1. drain old rusty coolant
2. put tap water + radiator flush cleaner, run about 10mins until engine warm
3. drain and flush with tap water continuously for 30mins
4. repeat 2 and 3
5. put tap water, run until the engine is warm, let it sit for 2 hours
6. drain, there is still a little bit rust color but it is way better than the first drain, 10 times better
I now put distilled water with Redline Water Wetter to the radiator. I did not put anitfreeze as weather here will not be freezing.
I know the water inside the engine that blocked by thermostat is still tap water, I will try to drain the whole system next week and fill with distilled water to better dilute the tap water that I scared it would cause problem.
11-15-2013, 11:38 PM
bad coolant
kawo Wrote:1. drain old rusty coolant
IT Needs a rust inhibitor!!!!!!
It may need cleaning/flushing with chemical - TSP or drain cleaner.
It does not need distilled water.
It does not need 'water wetter'!
11-16-2013, 03:59 AM
bad coolant
Oh, I thought the Redline Water Wetter is some kind of rust inhibitor.
Dumb question
11-18-2013, 07:43 PM
bad coolant
a good coolant is the Eneos and it has red color...
4age 16v to FR 20VT
  ClutchMaxPRO Clutches - Good or Bad? RolanTHUNDER 0 1,275 12-01-2022 09:55 AM
Last Post: RolanTHUNDER
  Bad vibrations /resonance starts at 5000 rpm izanagi 7 8,742 07-23-2015 05:02 PM
  AE86 Engine Coolant Temp Sensor izanagi 8 20,877 09-06-2014 05:47 PM
Last Post: izanagi
  20v coolant problem Bravothreezero 8 10,302 07-15-2013 03:25 PM
Last Post: Bravothreezero
  wich coolant? fax0815 7 17,506 09-30-2011 09:56 PM
Last Post: fax0815
