braided brake lines
10-24-2015, 01:17 PM
braided brake lines
Hi everyone,
I would like to buy a kit of braided brake lines for my 86 but I really don't know what brand to take.
Goodridge seems good but expensive.
Someone has another brand as good as Goodridge and cheaper ?
Thanks all.
10-25-2015, 02:04 PM
braided brake lines
I believe that Goodridge are approved for road use, worth checking if you are going to use the car on the road.
10-25-2015, 06:52 PM
braided brake lines
(10-25-2015 02:04 PM)totta Crolla Wrote:  I believe that Goodridge are approved for road use, worth checking if you are going to use the car on the road.
I don't need it approved for road.
10-25-2015, 08:10 PM
braided brake lines
I have Driftworks lines and I'm pleased with them. Good thick orange plastic around them aswell.
10-25-2015, 08:29 PM (This post was last modified: 10-25-2015 08:31 PM by d3nso.)
braided brake lines
Goodrige and expensive? They're ~135€ a set so pretty affordable in my opinion.
Other brands:
- Hel (approved) 135€
- Driftworks (not approved) 105€
- Spiegler (approved) 110€
Daily Beater: Civic EG5
Work in progress Car: AE86
11-02-2015, 09:07 PM
braided brake lines
Hi all,
Just bought a set of braided brake lines for my AE86.
The nipple that goes in the rear caliper seems to be the good one but the other nipple that screw with the copper line from the axle seems to be not correct.
Of course it's a female type but inside it's inverted flare (concave) and the end of the copper line that come from the rear axle is also inverted flare (concave).
In my mind, inverted flare against inverted flare will not work. Aim I right and do I need an adapter to convert it into male 3AN (convex) to do flare into inverted flare ?? or is it OK inverted flare against inverted flare ?
Sorry for my bad English I'm from Belgium
Thanks for your help.
11-05-2015, 10:46 PM
braided brake lines
Nobody
11-06-2015, 10:59 AM
braided brake lines
I'll see if I can find a brake line so I can check for you. I'd say it's fairly obvious that you shouldn't use the lines if the nipples are incorrect, it's only your life your risking after all.
11-06-2015, 11:02 AM
braided brake lines
In my opinion that won't work. Either return the line, have a new one made or buy another. Don't like the idea of fiddling with adapters in the brake system.
11-07-2015, 09:13 AM (This post was last modified: 11-07-2015 09:15 AM by izanagi.)
braided brake lines
The most crazy is that the seller at Driftworks said to me: "there is not problems with that. The braided lines are made by HEL and we already asked for that and HEL said that you can put it together without any problems."
My car without brakes is not their problems also.
  US-spec vacuum hard lines LordTD 2 5,086 04-27-2015 07:18 PM
Last Post: Project D
  goodridge SS brake lines fitting doubts wouter86 17 17,480 04-30-2014 06:33 PM
Last Post: wouter86
  rear window defroster lines zenki 3 5,468 11-15-2013 02:58 PM
  New fuel lines ? Komba 1 3,207 07-19-2013 10:09 AM
Last Post: Komba
  Toyota partnumbers OEM brake lines (front) IBMFD3S 6 7,450 01-10-2012 06:36 PM
Last Post: bozu
User(s) browsing this thread: 16 Guest(s)
