clutch problem
08-11-2008, 10:11 AM
clutch problem
Hi,
after installing new clutch and flywheel some noise and vibration appeared from clutch area. it appears when easing the gas pedal (at arround 3000 rpm). Ive changed gearbox and cardan shaft and flywheel also but same problem. Did anybody have same experience? thanks a lot. Integra Type R vs AE86 Levin |
08-11-2008, 10:35 AM
clutch problem
I have not exactly vibration but a strange sound that dissapear when i put the clutch pedal. The clutch kit is new.
**COROLLA EE80 - 4AGE 124HP** |
08-11-2008, 10:38 AM
clutch problem
yes, the noise and vibrations disappear when clutch pedal is pressed
08-11-2008, 05:49 PM
clutch problem
Did you change the clutch bearing that's sitting in the gearbox?
Big chance that that's causing the strange noises! I reject your reality and substitute my own! No more Panda.. Tricolor bastard! If it 'aint broke, fix it 'til it is |
08-11-2008, 06:04 PM
clutch problem
clutch bearing and pressure plate also changed?
No Smorking AE86 |
08-11-2008, 07:48 PM
clutch problem
pressure plate and clutch bearing changed also.
Now driven arround 300 km. The noise is different from bearing noise. And there is huge vibrations. All arround 3000 rpm. It stops when clutch pedal is pressed. Integra Type R vs AE86 Levin |
08-12-2008, 06:59 AM
clutch problem
Also, i changed clutch cover, clutch disc and clutch bearing but not flywheel. I have done 8000km with the same sound.
I dont feel much vibration but the sound and the bit of the vibration when i puss the clutch pedal disappear completely. **COROLLA EE80 - 4AGE 124HP** |
08-12-2008, 09:04 AM
clutch problem
yeah. it seem same.
08-12-2008, 10:05 AM
clutch problem
Somebody to help!
08-12-2008, 11:20 AM
clutch problem
I'm searching for the cause of the same problem you have.
My hachi began to vibrate when the bushings have been changed out to prothane (for sure the problem was there before, but i didn't noticed anything of it until the harder bushings have been built in). After that i changed the tranny mount, because it was worn. But no effort. I've bought a tranny, changed it (new release bearing and pilot bearing, new clutch plate, pressure plate and flywheel), but it is the same (this tranny is not a new or renewed one, but the noise and vibration is exaxtly the same, so i think it's not the tranny). Now my diff is rebuilt i will put it back this week, but i don't think, that it could be the cause. I've ordered new motor mounts, they will be changed out at the end of this month or in september. And i will rebuild my tranny next year. So if i find out something i will inform you. Daily driver: AE86 - 1985 zenki levin |
Clutch pedal problem | andee17 | 3 | 4,496 |
07-25-2013 11:57 AM Last Post: jondee86 |
Clutch problem | Rascal21 | 4 | 5,394 |
05-31-2013 06:00 PM Last Post: Alex170984 |
4agZe problem solved - 99% IC problem | Okami | 41 | 35,024 |
07-12-2012 04:49 PM Last Post: Okami |
AC problem? Idle problem? | KD2229 | 3 | 4,653 |
08-19-2009 02:08 AM Last Post: KD2229 |
Clutch Master Cylinder and Clutch Slave Cylinder fitment? | christsang7 | 2 | 5,014 |
07-01-2009 07:48 AM Last Post: jondee86 |
User(s) browsing this thread: 20 Guest(s)
