clutch pump on the geaboxx
03-21-2013, 08:57 PM
If the clutch slave cylinder is found to not be the problem, then check the master cylinder push rod. You need 1mm of free play in the push rod for the master cylinder. If you pre-load the master cylinder piston, it will cover up the return port in the cylinder and not allow the slave cylinder to retract. The adjustment is at the top of the clutch pedal arm. Dave W
03-26-2013, 09:33 AM
Project D Wrote:I believe what he mean is when the pedal is all the way up the clutch stay disengaged (or not fully engaged) yep this is what i mean i have orderd a new one i will post pics of the old one but the problem is fixt now i have the right one ;d ![]() me happy |
20v BT - which oil pump? | Mylesmck | 4 | 3,065 |
Fuel pump issue | DJexor | 11 | 5,832 |
fuel line hose from the pump | Wikizz | 4 | 6,263 |
10-16-2017 07:11 PM Last Post: jdm86gtz |
4age smallport oil pump in bigport engine? | ditn | 2 | 8,418 |
12-06-2014 08:10 PM Last Post: ditn |
Oil pump question | megabob | 2 | 5,082 |
03-05-2014 05:37 AM Last Post: oldeskewltoy |
