corolla idles way to high HELP PLEASE
11-30-2011, 08:02 AM
i know this is an ae86 forum but i just got a te72 and cant find nothing about. the car runs great and strong runner but it idles way to high probly around 2k and it sounds like its climbing, its gettin to the point to where i can barrely put it in reverse and gears grind. the guy i got it from said he adjusted the idle cause of the cold weather. it was idleing at about 1500 at warm up then drop to about 1k. my gas pedal is pretty stiff, how do i adjust the idle back to where its suppost to be should i loosen up the throttle cable any ideas will help thanks.
my first 1986 ae86 sr5 daily driver project paid 700 for it straight body not one dent. |
11-30-2011, 08:49 AM
![]() If the gas paddle feels stiff or very "heavy" my only encounter with this problem was change the gas paddle cable. It will make the feel of your gas paddle increadibly different. Maybe you can oil it but I'd say if it hasn't been swapped in 30 years give it a gift. (and also your foot ![]() Cars: "99 Lexus IS200 "86 AE86 Kouki Panda Levin GT-Apex (restore project) "84 AE86 Zenki Blue Levin (project racer) Motorcycles: "02 Yamaha R1 "02 Honda Hornet S "08 BMW R1200GS |
11-30-2011, 09:47 AM
Even wen its warm it willl still idle that high. But if you say its normal ill take your word on that thanks.
11-30-2011, 03:26 PM
What engine are we talking about, the 2T? Does it have carbs or efi?
11-30-2011, 03:46 PM
Its carbed, I think its called the 3tc
11-30-2011, 05:04 PM
Ok, so it´s different.
3 things I suggest to check: Have you you played with the idle adjusting screw on your carburettor? Does the idle change? Check the face of the sparkplugs? If its white you got an airleak somewhere in you intake. Unlink the throttle cable, an try to push in and out on the carbs end, does it move alright or gets stuck (spliced cable)? 1979 Toyota Corolla KE35 1983 Toyota Corolla AE86 1985 Toyota Corolla AE86 |
11-30-2011, 09:34 PM
I adjusted the screw and it sounds normal now but wen I tap the gas the idle wont drop back down
12-01-2011, 01:44 AM
Count how many pieces parts links cables levers & points of contact there are between your foot and the butterfly/throttle plate inside the carburetor's bore/
All of these have to operate freely & smoothly, no corrosion dirt smegma, outside & inside the carb and ALL of its throttle & choke linkage, that's where something is hanging up. Also, the engine speed has nothing at all to do with the trans grinding, that is only because the clutch is not disengaging completely, not RPM! So what! |
12-01-2011, 10:05 AM
86_ae86_coupe Wrote:I adjusted the screw and it sounds normal now but wen I tap the gas the idle wont drop back down Check if blade is returning to zero/closed position when you blip the throttle. |
High-beam warning lamp | Mylesmck | 4 | 1,757 |
Engine stress at high speeds | gh0st | 6 | 2,869 |
Kaaz 1.5 way Diff - Driveshaft Compatability | chrisae86 | 1 | 2,493 |
4AGE 16V engine overheat when at high speed | chenfon | 32 | 23,464 |
TUV RHD AE86 Germany (help please) | 4dori | 9 | 7,396 |
07-17-2019 07:42 PM Last Post: Hachigo83 |
