custom made RCA question: what height?
02-22-2005, 02:26 PM
A friend of mine offered to fabricate a pair of RCA (Roll Center Adjusters). My question is how fat (what height) should the RCA be, having in mind that i'll be installing Tokico HTS102 all around (short stroke conversion).
...or if someone can just measure one's own!
1984 Toyota Corolla 4AGE 20v
2007 Subaru Impreza STi
02-22-2005, 02:47 PM
30mm is ok if you shorthen the strut 40mm.
02-22-2005, 06:23 PM
The best way to determine the correct hight, is measuring it. Lower the car to your desired hight and look how much the hub needs to move in order to have the lower control arm perpendicular to the ground.
Measure with the normal # of people in the car and half a tank of gas.
This would give you the best possible negative camber gain.
02-23-2005, 01:18 PM
thanks for the replies! :wink:
02-24-2005, 01:16 AM
I'd say 40mm for a short stroke HTS set-up, since they are VERY short front stroke.
A good rough guide to RCA height should be about equal to or just under the amount you lower the car.
02-24-2005, 10:52 AM
NoHachi Wrote:The best way to determine the correct hight, is measuring it. Lower the car to your desired hight and look how much the hub needs to move in order to have the lower control arm perpendicular to the ground.
Does anyone know what is the stock position of the control arms? Are they exactly perpendicular? My car came with some changes in the suspension so i can't use its current status as a criteria for the angle.
  RCA sizing kazi 3 4,601 01-28-2018 10:44 PM
Last Post: kazi
  Custom Dash Cluster kazi 14 20,239 10-24-2017 09:05 PM
Last Post: kazi
  Gear end , drive pinion height filh 5 11,156 06-27-2013 12:29 AM
Last Post: filh
  Stock ride height xrgeorg 11 12,448 10-08-2011 07:38 AM
Last Post: xrgeorg
  4agZe custom fabrication - need pictures Okami 5 13,519 08-08-2011 03:37 AM
Last Post: Saber
