diff oil
08-20-2007, 05:53 PM
diff oil
Im looking to change my diff oil this week, this is the first time i've done this so i could do with abit of advice, the 2 main things i need to know is what oil and how much
i'm currnetly looking at getting this stuff http://www.theoilman.co.uk/index.php?act...oductId=11 , will this be ok, or is there something better you can recomend,
and of course how much will i need to fill the diff, also is there any thing else i need to know,
as far as im aware the diff has done 140,000km
cheers for your help
hopper
08-20-2007, 07:44 PM
diff oil
You need a 24mm socket or open ended wrench. Remove the filler bolt BEFORE the drain bolt. This is just to make sure you will be able to add the new fluid after you drain the old stuff. I use Motul 90pa with my Kaaz 2-way. If you have an OEM LSD or open diff you should use 80-90W.
[Image: AEU86 AE86 - diff oil]
Peter Diaz
http://www.shiftgearclothing.com
http://www.ectoyotas.com/forum/
http://www.facebook.com/elfatherae86
08-20-2007, 07:55 PM
diff oil
Shavings/Filings are normal so dont panic.
24mm Socket, open top, then open bottom to drain oil, secure bottom & pump in the new diffoil until it starts to overflow. Then secure that particular hole with the 24mm.
I think it takes just over 1ltr
08-20-2007, 07:57 PM
diff oil
1.3 liters to be exact Big Grin
08-20-2007, 07:59 PM
diff oil
cheers
does that oil in the link look good enough, i don't know much about oils
  trans oil, lsd oil change Apolan 9 17,599 10-01-2014 03:57 PM
  Oil cooler -> low oil pressure Jan Pedersen 24 31,793 06-06-2013 07:36 PM
Last Post: Deuce Cam
  Urgent replies needed DIFF OIL + refresh Okami 6 6,801 06-17-2012 09:56 PM
Last Post: Okami
  What Diff Oil For a Clutch plate diff? jamieae86 10 14,694 12-16-2011 11:14 AM
Last Post: bakonick
  4AGE crankcase gas and oil pressure too high, sprinking oil demogun 5 8,112 10-01-2011 09:47 AM
Last Post: demogun
