diff oil
07-11-2008, 01:11 AM
diff oil
name of which oil i use for the diff also how do we check level???
07-11-2008, 05:19 AM
diff oil
depends what you have, if you have a KAAZ lsd use the KAAZ diff oil, if you have TRD like me use TRD FR or cusco just use redline. if you dont have a diff oil cooler just top it off till you see the oil go out, if you have a diff oil cooler after toping it off run the car around the block and jack it up again then top it off.
[Image: AEU86 AE86 - diff oil]
07-11-2008, 09:01 AM
diff oil
Oil type depends on if it is LSD or not. Any big name brand
can supply you with both.
As said above... pump oil in thru the upper plug until it starts
running back out... thats the correct level. Hard core drifters
like to add an extra half a litre by jacking up one side and
letting the oil run down the axle tube. Supposed to help keep
oil in the gears during long difts in one direction Cool
Cheers... jondee86
07-17-2008, 01:54 AM
diff oil
Also consider using LSD additive from GM, they sell it for the Chevrolet Corvette.
1987 328ci SR20DET Drift Car
2002 Corolla CE Daily Driver
http://www.TheTunerSource.com
07-17-2008, 09:18 PM
diff oil
If not using LSD: 80W90
07-17-2008, 10:48 PM
diff oil
For LSD use 75W140. There is one from Castrol for example.
Greets raki
http://www.sg-rallyesport.de
  trans oil, lsd oil change Apolan 9 17,599 10-01-2014 03:57 PM
  Oil cooler -> low oil pressure Jan Pedersen 24 31,794 06-06-2013 07:36 PM
Last Post: Deuce Cam
  Urgent replies needed DIFF OIL + refresh Okami 6 6,801 06-17-2012 09:56 PM
Last Post: Okami
  What Diff Oil For a Clutch plate diff? jamieae86 10 14,694 12-16-2011 11:14 AM
Last Post: bakonick
  4AGE crankcase gas and oil pressure too high, sprinking oil demogun 5 8,112 10-01-2011 09:47 AM
Last Post: demogun
