engine boggs when reving
11-26-2007, 06:41 AM
Hey guys ok so heres the deal, the engine starts up fine and idles fine too, but when I go to rev the engine I have to slowly ease on the gas pedal and gradually rev it, if I try to rev it really fast it wants to kill the engine. Any suggestions ? thanks.
heres a video. http://youtube.com/watch?v=-udVchZyjBQ |
11-26-2007, 07:07 AM
Did u checked ur sparkplugs allready ?
And how is the timing on the sparksignal ? And the sparkwires r k too ? Check that first maybe it whill help Grtz Love it or hate. It still is and still stays a beautifal car!!! Oooohw how I love the Ae86 You have the right to remain stupid !!! Toyota for life !!! |
11-26-2007, 10:23 AM
Sure sounds and behaves like it is over-advanced !!! As above, check
your ignition timing is set to specifications. Or just back it off a bit, and see if it improves. Cheers... jondee86 The reasonable man adapts himself to the world; the unreasonable one persists in trying to adapt the world to himself. Therefore, all progress depends on the unreasonable man. |
11-26-2007, 10:56 AM
Okay ill check that first thing in the afternoon, btw , there is a MSD Blaster Coil installed , would that effect anything of the timing ?
11-26-2007, 07:23 PM
I don't think that has anything to do whit ur timing or what so ever, it just gives a better spark on ur sparkplugs.
check the ignitioncap too if there is any corosion in there. If so clean that up with som light sandpaper and then spray som contactspray on it and be sure that u put the cap on so there can't com water or moister in the cap. Grtz Love it or hate. It still is and still stays a beautifal car!!! Oooohw how I love the Ae86 You have the right to remain stupid !!! Toyota for life !!! |
11-26-2007, 07:32 PM
take a look at the injectors plugs also and check your TPS ...
AE86 FANATIC!!! |
11-26-2007, 07:54 PM
Sounds to me like an bad TPS angle...
11-27-2007, 04:58 AM
okay so i checked the spark plugs , spark plug wires, inside of the dizzy cap, everything was good, only thing i have yet to check it the TPS , how do I go about checking that ? is there a special tool i need to check it?
11-27-2007, 07:15 AM
alimonos Wrote:take a look at the injectors plugs also and check your TPS ... AE86 FANATIC!!! |
11-27-2007, 08:26 AM
Hey... if it revs to redline and idles... but bogs and rattles when you
crack the throttle wide open, having too much advance is a good bet. Check the timing. You have to jumper (temporarily connect together) two of the pins in the diagnostic plug (probably T and E1). Then check that it has the specified amount of advance at idle (probably 10 deg). You will need a timing light. Adjust by loosening off the clamp on the base of the distributor, and twisting the distributor forward or back. Tighten the clamp when finished When you take the jumper out the amount of advance will increase as the ECU dials in extra to take the total up to what the engine needs. Can't remember how much more... maybe to 28 deg total ?? Someone else will know. It's not important. Ten deg at idle with the jumper in, and you are good to go Cheers... jondee86 The reasonable man adapts himself to the world; the unreasonable one persists in trying to adapt the world to himself. Therefore, all progress depends on the unreasonable man. |
toyota a series engine....can a fwd corolla engine be used | 210 datsun guy | 5 | 8,222 |
Reving/Idle Problem??? | jamieae86 | 10 | 10,378 |
11-24-2011 08:03 PM Last Post: max_ae86 |
Need engine,any engine | Apolan | 25 | 18,586 |
10-29-2006 06:55 PM Last Post: ZaX |
User(s) browsing this thread: 15 Guest(s)
