exhaust manifold
06-19-2005, 02:03 PM
exhaust manifold
Hey Guys,
OK I definatelly have a leak somewhere in my exhaust. We think its the bit where the header goes from 2 to 1 pipe. I'm guessing it may have to do something with the screw holes for the heatshield or somethign as the heatshielding is coming loose. Its a good change that when I remove the heatshields completely I'll be able to see how bad it is and hopefully fix it easily.. If it turns out to be worse then I expect, this would be a good option to start discussing alternatives on our board. What options are there to replace the header with something nicer? I could go with a stock replacement but somehow I think thats not the road I'd take... Fensport seems to sell some direct replacement stuff, no idea how good that is... On club 4ag I read about pacesetter headers that could be an option. What else is out there? Greetz, Bastiaan "mux213" Olij Moved down under, no more hachi ![]() |
06-19-2005, 03:42 PM
exhaust manifold
By most accounts the standard headers are pretty good, its only when you really start tuning the engine that they become an issue.
Lots of UK owners use the Janspeed manifold though, seems to have a good following. ![]() |
06-19-2005, 04:43 PM
exhaust manifold
Jon,
But I heard somewhere the janspeed header doesn't bolt right up to the stock downpipe? Greetz, Bastiaan "mux213" Olij Moved down under, no more hachi ![]() |
06-19-2005, 05:27 PM
exhaust manifold
Also we have the steeringaxle on the exhaust side. So most RHD manifolds won't fit ours.
Broken down 1984 Trueno HB ![]() |
06-19-2005, 07:14 PM
exhaust manifold
Aico, good point!
06-19-2005, 07:51 PM
exhaust manifold
Didn't think of that, guess you need to look to america, but pacesetter don't have a great rep from what i've heard.
06-20-2005, 09:53 AM
exhaust manifold
mux, if you can temporarily fix yours - soon I can offer tested 4-1 header (I built it, need to be compared with stock one on dyno).
If you prefer - I have spare original header also. |
06-20-2005, 10:17 AM
exhaust manifold
Jamie sounds interesting! let me know!
I am going to try and fix it first though.. I did hear that a 4-2-1 design should be better then a 4-1 design? Greetz, Bastiaan "mux213" Olij Moved down under, no more hachi ![]() |
06-20-2005, 10:22 AM
exhaust manifold
I made 4-1 TRD copy from mild steel.
Yes, 4-2-1 is better for smooth torque curve but 4-1 gives more power - in narrower range. I built 4-1 with long primaries - to avoid power peak at very high RPM so the header is usefull to gain power even in 6000 RPM range (will test it on dyno and see exactly what's going on). I can fabricate 4-2-1 if you prefer (it's even easier becouse it doesn't need 4-1 merge collector). |
06-20-2005, 10:37 AM
exhaust manifold
Aico Wrote:Also we have the steeringaxle on the exhaust side. So most RHD manifolds won't fit ours. Steering column vs greddy exhaust manifold/turbo/downpipe - 1:0 Couldn't sleep 3 nights because of this problem. Manifold is for RHD cars. Drifting - best fun you can have in your car with your pants on! |
Smallport inlet manifold | totta Crolla | 6 | 3,744 |
01-17-2022 05:14 PM Last Post: oldeskewltoy |
4age blue top from MR2 same intake manifold? | dinkers542 | 8 | 11,029 |
11-02-2014 05:24 PM Last Post: ditn |
4AGTE turbo manifold questions | daveskatesallday | 3 | 5,171 |
08-13-2013 07:38 PM Last Post: daveskatesallday |
20v silvertop exhaust manifold on 16v 2nd version tvis motor | Apsogos | 17 | 23,230 |
11-22-2012 11:15 PM Last Post: Apsogos |
Intake Manifold | Bentley | 6 | 10,045 |
04-10-2011 07:59 AM Last Post: Jan Pedersen |
User(s) browsing this thread:
