ford type 9 gearbox with 4age engine
12-14-2014, 12:14 PM
Im gonna use the 6speed gearbox for my rallycar
Would be interested in the perfect 6speed gearbox as well in the later future when everything is up and running |
12-20-2014, 01:08 AM
to oldeskeweltoy :
I prefer to keep Toyota clutch fork and release cylinder , than using the Ford cable system. The Ford type 9 gearbox is a Quaife kit (straight pinions), which should be stronger than Lexus and Nissan gearboxes TO Totta Crolla ; Fensport has also a bellhousing in stock . Where would it be better to buy it ? Fensport or Motorsport -Tools ? (Knowing i want to fit the release cylinder and fork pivot from the ae86) On pics , I can't see the place to fit the release cylinder. Phil Filh Save the RWD cars |
12-20-2014, 03:10 AM
(12-20-2014 01:08 AM)filh Wrote: to oldeskeweltoy : The Lexus/Toyota gear case is stronger then the Nissan version. As to strength as compared to a Ford type 9 box... I'm not qualified to answer since I don't know the Ford gearbox. What I do know is this transmission was used by Toyota in a 3000# car(Altezza, and IS200), these cars all have over 200hp, and more importantly all are over 160# feet of torque. In each case these are far more loads then a 4AGE, and a Corolla's mass will place on them Dan - You can | .... OR you can ask for help!!! OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
12-20-2014, 03:47 AM
Hi filh, I would buy from whoever was prepared to guarantee it would fit your car without issue.
12-20-2014, 09:13 PM
(This post was last modified: 12-20-2014 09:25 PM by oldeskewltoy.)
As far as bolt in....
The only custom work REQUIRED would be to either shorten the stock driveshaft front section 1/2" - what I did in mine, OR go custom one piece. In either case... you will need to source a transmission yoke from something that ran the W5x transmission, Again in my case I sourced the front half of a MkII Supra driveshaft, and had that shortened and fitted to the rear half of the Corolla driveshaft - as seen below custom carbon fiber one piece EDIT - for full disclosure... the converted J160 adds 10 kilos over a T50 Dan - You can | .... OR you can ask for help!!! OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
12-21-2014, 05:18 PM
Ditn, for a true race car you will need close ratio gearbox. Forget any standard gearbox.
Case is not so important, ford, toyota ..... ratios are. If i had enough money, my 4AGE would have 4AGE->Ford t9 bell and some caterham 6speed close ratio behind. I guess that's around 2000-3000euro total. It is much easier to find T9 box and gears than Toyota ones. |
12-21-2014, 06:29 PM
Uzelac : correct . I use a TRD close ratios, and it's ok . but it's only a stock upgrade about ratios.
all parts remaining the same . And it's harder and harder to get those parts (For example : input shaft bearing) Here in Belgium, and west Europa , it's hard to find gearbox like W58 , and Nissan , Lexus etc. Buying parts overseas involving high customs charges . An alternative seems to be Lampola (from Finland Esa Peltonen), dog Box , but you get same problem with taxes ,in Finland, as non European union member. Still asking myself where to buy the adapted type 9/T50 bellhousing , as i want to keep hydraulic clutch system and Toyota clutch fork . Looks like the two engine supports , bolted on block and on T50 bellhousing , are forgotten on . bellhousing adaptation. Maybe not to important, but as it is for rallying ......? any advice welcomed Phil Filh Save the RWD cars |
12-21-2014, 08:52 PM
(This post was last modified: 12-21-2014 09:03 PM by totta Crolla.)
My Type 9 bellhousing has done thousands of miles of rallying, most of it on broken concrete and is still fine even without the extra supports.
Every bellhousing I have seen allows for the stock hydraulic clutch slave and fork. Here is another bellhousing for you and I can personally vouch for the seller. http://cbradleymotorsport.co.uk/transmis...-ford.html An analogue brain in a digital World |
12-21-2014, 11:04 PM
(This post was last modified: 12-21-2014 11:29 PM by Uzelac.)
(12-21-2014 06:29 PM)filh Wrote: Uzelac : correct . I use a TRD close ratios, and it's ok . but it's only a stock upgrade about ratios. Finland is part of EU Not sure if Lampola has dogbox, mine is lampola and is standard syncro mesh, but short ratio, like TRD. I can understand problems with parts for TRD, thats one more reason to go with Ford parts, easily avaliable. BTwo if you need w5x I can help you get it, they are cheap herein Serbia and it would be cheap to ship it to Germany, I have an relative in Bocholt, that's practicaly Holland, shouldn't be too far for you together there and pick it up |
12-23-2014, 01:28 AM
Uzelac : on Esa Peltonen site :http://www.esapeltonen.fi/ refering to AE86 parts the gearbox is well called Dogbox (3 models).
I already have bought a Type 9 Quaife box , short ratios , straight pinions and synchros Totta Crolla : ok , lets forget the extra supports (time gain when removing :-) ) will probably order from Fensport or motorsport-tools. And i saw a link on Driftworks where it show the use of T50 gearbox support, mixed with Ford bushing http://www.driftworks.com/forum/drift-ca...ics-9.html Bests regards Phil Filh Save the RWD cars |
Ford gearbox | totta Crolla | 0 | 1,295 |
02-15-2022 05:21 PM Last Post: totta Crolla |
4ac gearbox on 4age | hachirokkos | 2 | 6,191 |
05-24-2016 10:16 PM Last Post: banpei |
toyota a series engine....can a fwd corolla engine be used | 210 datsun guy | 5 | 8,068 |
7AGE to W58, cluth type? | slowboy2 | 3 | 5,438 |
Type of carbs to suit 4ag | kpretro84 | 23 | 23,805 |
02-09-2013 02:29 AM Last Post: bakonick |
