just picked up a 86 sr5
06-04-2008, 06:51 AM
i wanna do a swap what do u guys suggest for a motor?....im new to this too
06-04-2008, 08:30 AM
if you are new, dont swap anything for now, do a few weeks of reading and learning first Smile
06-04-2008, 10:33 AM
And drive the car around abit first. Make sure the rest of the car is in good nick. Also think about the fact that you don't want to just change the engine, suspension work is just as important as is the rear axle. All these are less appropriate to a higher performance car compared to a GTS, not to mention that after 20 odd years, suspension parts will have warn out anyways. You might even want to consider first improving the car, and take the engine upgrade for later.
That all said, look around in the project section. Plenty information around for swaps of different engines. Popular are:
- silvertop or blacktop (20v 4ag)
- 4agze (supercharged) or 4agte (turbo)
- nissan engine from a 200SX
- honda engine from a S2000
But all cost $$$$ to put in and require you to do your homework before attempting to do a swap yourself.
06-04-2008, 01:24 PM
Mux213 Wrote:And drive the car around abit first. Make sure the rest of the car is in good nick. Also think about the fact that you don't want to just change the engine, suspension work is just as important as is the rear axle. All these are less appropriate to a higher performance car compared to a GTS, not to mention that after 20 odd years, suspension parts will have warn out anyways. You might even want to consider first improving the car, and take the engine upgrade for later.
The only good thing from Toyota with a "Z" on it is 2J-ZE. Thumbs up!
In my opinion, I just think the 4A-GZE is rubish, but it is just my two cents, never in my life would I swap a Z for a regular 4A.
[Image: AEU86 AE86 - just picked up a 86 sr5]
06-13-2008, 11:25 PM
I suggest getting at least a small port red top as a good base for modification.
1987 328ci SR20DET Drift Car
2002 Corolla CE Daily Driver
http://www.TheTunerSource.com
06-14-2008, 12:27 AM
Weld the diff, have some fun, learn to drive, & again have some fun, then burst your balls paying for mods like we do. So many people like me go for the mods direction 1st.
  where to start on sr5-GTS swap dinkers542 0 3,406 12-20-2014 02:13 AM
Last Post: dinkers542
  can i just slam a oem turbo on it ? MC_JP 3 6,263 12-17-2014 11:04 PM
  are sr5 rotors the same as gt-s? Rickybobby 3 5,662 07-28-2013 11:54 PM
Last Post: jondee86
  Mikuni carb help just wont balance megabob 3 5,323 01-01-2013 10:32 PM
Last Post: allencr
  sr5 coupe breaks? help!!!! 86_ae86_coupe 10 11,499 11-16-2011 06:31 AM
Last Post: 86_ae86_coupe
