just picked up a 86 sr5
06-04-2008, 06:51 AM
i wanna do a swap what do u guys suggest for a motor?....im new to this too
06-04-2008, 08:30 AM
if you are new, dont swap anything for now, do a few weeks of reading and learning first
06-04-2008, 10:33 AM
And drive the car around abit first. Make sure the rest of the car is in good nick. Also think about the fact that you don't want to just change the engine, suspension work is just as important as is the rear axle. All these are less appropriate to a higher performance car compared to a GTS, not to mention that after 20 odd years, suspension parts will have warn out anyways. You might even want to consider first improving the car, and take the engine upgrade for later.
That all said, look around in the project section. Plenty information around for swaps of different engines. Popular are: - silvertop or blacktop (20v 4ag) - 4agze (supercharged) or 4agte (turbo) - nissan engine from a 200SX - honda engine from a S2000 But all cost $$$$ to put in and require you to do your homework before attempting to do a swap yourself. Greetz, Bastiaan "mux213" Olij Moved down under, no more hachi |
06-04-2008, 01:24 PM
Mux213 Wrote:And drive the car around abit first. Make sure the rest of the car is in good nick. Also think about the fact that you don't want to just change the engine, suspension work is just as important as is the rear axle. All these are less appropriate to a higher performance car compared to a GTS, not to mention that after 20 odd years, suspension parts will have warn out anyways. You might even want to consider first improving the car, and take the engine upgrade for later. The only good thing from Toyota with a "Z" on it is 2J-ZE. In my opinion, I just think the 4A-GZE is rubish, but it is just my two cents, never in my life would I swap a Z for a regular 4A. |
06-13-2008, 11:25 PM
I suggest getting at least a small port red top as a good base for modification.
06-14-2008, 12:27 AM
Weld the diff, have some fun, learn to drive, & again have some fun, then burst your balls paying for mods like we do. So many people like me go for the mods direction 1st.
where to start on sr5-GTS swap | dinkers542 | 0 | 3,248 |
12-20-2014 02:13 AM Last Post: dinkers542 |
can i just slam a oem turbo on it ? | MC_JP | 3 | 5,982 |
12-17-2014 11:04 PM Last Post: oldeskewltoy |
are sr5 rotors the same as gt-s? | Rickybobby | 3 | 5,400 |
07-28-2013 11:54 PM Last Post: jondee86 |
Mikuni carb help just wont balance | megabob | 3 | 5,096 |
01-01-2013 10:32 PM Last Post: allencr |
sr5 coupe breaks? help!!!! | 86_ae86_coupe | 10 | 10,834 |
11-16-2011 06:31 AM Last Post: 86_ae86_coupe |
