need expirienced ae86 owners..webber carbs help..frustrated
06-25-2010, 01:07 AM
my 4age has 40mm webber carbs...i was running a facet fuel pump which was deemed terrible for the carbs because of the lack of volume it put out...the facet put out about 7-8 psi and had a pulsating fuel delivery....that is the reason i thought my car would die after about 5 minits with out using the gas pedal...so i got a carter p4070 fuel pump which delivers 5 psi at 70 gal. per hour...i had heard a good volume was what the carbs needed...so i install the fuel pump..crank the engine...and it runs for 3 minits before gas starts leaking out the front of the carbs...gas also leaked out the back of the carbs..im hoping i didnt blow the seals on the carbs...my thought is the carbs wer tuned with the facet pump so they werent set to run with the carter pump..anyway i need some help with this issue...i got my information on the internet...what do u guys think?
06-25-2010, 08:44 AM
You may have to check that needle valve in carbs closes properly and if there is no return from carbs back to fuel tank, then you need a fuel pressure regulator.
[Image: AEU86 AE86 - need expirienced ae86 owner...frustrated]
http://www.alamomotorsports.com/weber/re...lpump.html
This is how I did it with Facet Redtop:
http://i33.photobucket.com/albums/d61/Kl...ti/6-7.jpg
Here you can find a part list and exploded views to Weber carb:
http://www.webercarburator.com/carbdetai...oe_151.htm
"Tämmösellä modernilla autolla, niin mun mielestä, ei tämmöstä kisaa voi ajaa. Tää käy kunnon päälle eikä riitä aivot tähän touhuun!"
""With a modern car like this, in my opinion, a competition like this can't be driven. It's too physical and your brains can't cope with this stuff"
-Henri Toivonen 2.5.1986-
http://www.youtube.com/watch?v=OwgB4Xs4LVQ
06-25-2010, 09:00 AM
Some good advice, and nice pics here...
http://forums.pelicanparts.com/porsche-9...setup.html
Cheers... jondee86
06-25-2010, 01:21 PM
You will want a fuel regulator in the fuel delivery line before the carbs to drop the pressure right down - check the pressure the webers need - IIRC its under 5psi.
You can run carbs on the EFI pump if you need to as well, just make sure there is a tank return line before the fuel regulator so the unused fuel gets sent back to the tank.
Sounds like they probably arent set up properly - best start over.
I have a manual for Mikuni Solex, they are very close match to the webers, so have a read and apply it to the DOCE's you have - should give you some ideas to start with.
http://eight-six.co.uk/?page_id=93
http://www.eight-six.co.uk - read the blog!
UK AE86 Forum - http://www.phpbber.com/phpbb/index.php?m...ghtsixcouk
  Need help identifying this! takumi_mt 4 1,131 04-05-2024 09:17 AM
Last Post: takumi_mt
  TRD ECU need help ps13michi 5 4,130 02-18-2022 10:42 AM
Last Post: ps13michi
  Need some help DJexor 4 5,440 03-13-2018 05:37 PM
Last Post: pack
  JDM trueno not starting. need help! kazi 8 8,946 03-12-2017 05:05 PM
Last Post: kazi
  Stack display system, need help Jimmi The Kid 1 4,358 01-15-2017 10:52 PM
