need some help guys
04-27-2007, 12:48 AM
need some help guys
ok this is what I have so far.. car started up and ran kind of good for some weeks I changed the transmission after that I went to pull the starter and sparks came out,( I know i have blown fuses).. well after all that happened I went to rewire my stock gauge cluster and noticed that some lights weren't lighting up.. I replaced all the blown fuses and all the relays and the two breakers... so here's the problem car wont start or kick over, the only thing that starts up is the starter,I can hear the fuel pump, and the gauges. what could it be..
04-27-2007, 08:06 PM
need some help guys
Is it a ignition problem?
Have you checked the igniter, distributor, sparks, cables, etc? |
04-27-2007, 09:21 PM
need some help guys
no i'm getting power.. i'll check all of what you said
Need help identifying this! | takumi_mt | 4 | 1,278 |
TRD ECU need help | ps13michi | 5 | 4,422 |
Some wiring help needed | DJexor | 5 | 5,754 |
Need some help | DJexor | 4 | 5,613 |
03-13-2018 05:37 PM Last Post: pack |
JDM trueno not starting. need help! | kazi | 8 | 9,255 |
