need some help guys
04-27-2007, 12:48 AM
need some help guys
ok this is what I have so far.. car started up and ran kind of good for some weeks I changed the transmission after that I went to pull the starter and sparks came out,( I know i have blown fuses).. well after all that happened I went to rewire my stock gauge cluster and noticed that some lights weren't lighting up.. I replaced all the blown fuses and all the relays and the two breakers... so here's the problem car wont start or kick over, the only thing that starts up is the starter,I can hear the fuel pump, and the gauges. what could it be..
04-27-2007, 08:06 PM
need some help guys
Is it a ignition problem?
Have you checked the igniter, distributor, sparks, cables, etc?
04-27-2007, 09:21 PM
need some help guys
no i'm getting power.. i'll check all of what you said
  Need help identifying this! takumi_mt 4 1,156 04-05-2024 09:17 AM
Last Post: takumi_mt
  TRD ECU need help ps13michi 5 4,190 02-18-2022 10:42 AM
Last Post: ps13michi
  Some wiring help needed DJexor 5 5,608 05-18-2019 01:50 PM
Last Post: DJexor
  Need some help DJexor 4 5,460 03-13-2018 05:37 PM
Last Post: pack
  JDM trueno not starting. need help! kazi 8 9,018 03-12-2017 05:05 PM
Last Post: kazi
