need some info on my AE86
02-19-2009, 12:27 PM
heshan Wrote:thanks jondee86. this is awesome. the backfire seems to have got much more aggravated the past few days.heshan, I'm going to make a general comment here in regards to trouble shooting car problems... deal with one thing at a time. You have to reduce the number of possibilities by eliminating them one at a time. Checking and setting each adjustment to factory specifications is a good place to start. In your case I would suggest you check that the cam timing is correct, and then check the ignition timing. These are the items most likely to cause a drop off in high rpm power and engine back firing. And I take it the back firing is occurring in the exhaust ?? Fuel cut on overrun is normal and should be barely noticeable. Once the engine is up to temperature, it should be the same every time you coast with your foot off the gas. Fiddling with the TPS can upset the transition from "on-throttle" to "idle" and cause the car to lurch when driving in slow stop-go traffic. Far too many people fiddle with the TPS unnecessarily !! Oh, and if you get a clunk when changing gears, it would be worth checking the universal joints and the centre driveshaft bearing for loose or excessive movement. Cheers... jondee86 |
02-19-2009, 06:17 PM
Thanks Jondee86 for pointing out some possible failure points. I'll be back with the mechanics report next time. Thank you all for your help. you guys are awesome..
Need some help | DJexor | 4 | 6,087 |
03-13-2018 05:37 PM Last Post: pack |
Toda timing info - with good general 4AG timing info too | oldeskewltoy | 0 | 5,546 |
Injector sizes info | ZaX | 19 | 38,503 |
07-17-2013 01:54 AM Last Post: jondee86 |
frame/chassis rails info | Tig | 14 | 23,310 |
12-22-2012 10:38 PM Last Post: Tig |
Collecting info for w58 conversion | ditn | 1 | 5,188 |
06-01-2012 08:59 PM Last Post: ditn |
