need some info on my AE86
02-19-2009, 12:27 PM
heshan Wrote:thanks jondee86. this is awesome. the backfire seems to have got much more aggravated the past few days.
also one more thing about the abnormal slowing down of the car is that it doesnt happen all the time. I only happens on and off mostly when the engine heats up.. what you think jondee86??
heshan, I'm going to make a general comment here in regards to
trouble shooting car problems... deal with one thing at a time.
You have to reduce the number of possibilities by eliminating them one
at a time. Checking and setting each adjustment to factory specifications
is a good place to start. In your case I would suggest you check that the
cam timing is correct, and then check the ignition timing. These are the
items most likely to cause a drop off in high rpm power and engine
back firing.
And I take it the back firing is occurring in the exhaust ??
Fuel cut on overrun is normal and should be barely noticeable. Once the
engine is up to temperature, it should be the same every time you coast
with your foot off the gas. Fiddling with the TPS can upset the transition
from "on-throttle" to "idle" and cause the car to lurch when driving in slow
stop-go traffic. Far too many people fiddle with the TPS unnecessarily !!
Oh, and if you get a clunk when changing gears, it would be worth
checking the universal joints and the centre driveshaft bearing for loose
or excessive movement.
Cheers... jondee86
02-19-2009, 06:17 PM
Thanks Jondee86 for pointing out some possible failure points. I'll be back with the mechanics report next time. Thank you all for your help. you guys are awesome..
  Need some help DJexor 4 6,106 03-13-2018 05:37 PM
Last Post: pack
  Toda timing info - with good general 4AG timing info too oldeskewltoy 0 5,566 11-05-2016 01:34 AM
  Injector sizes info ZaX 19 38,563 07-17-2013 01:54 AM
Last Post: jondee86
  frame/chassis rails info Tig 14 23,388 12-22-2012 10:38 PM
Last Post: Tig
  Collecting info for w58 conversion ditn 1 5,197 06-01-2012 08:59 PM
Last Post: ditn
