noise from engine bay
09-28-2008, 03:50 PM
Hi folks,
not been around for a while as I've been a bit too busy at home I took the cam out yesterday and it seems to have developed a high pitched whistling noise thats cooming from around the injection area. I believe its a leak on the vacuum side but can't find it. Anyone any ideas on what to check, how to check it. What can I spray around under there to identify where its a problem thanks for the help in advance cheers Paul Live life on the red line |
09-28-2008, 03:59 PM
put some washing up liquid around the gasket, if it starts bubbling anywhere, you should find the culprit.
Is it idling rough at all? |
09-28-2008, 04:04 PM
idling sometimes is a bit arratic... a bit lumpy is the best way to describe it
09-28-2008, 04:16 PM
since you did the cam or before aswell? usually an eratic idle (mild seeking) is a vacuum leak. so do a bit of checking and see what you can find.
09-28-2008, 05:16 PM
sorry for the confusion....need to get my wording right
Cam=car=Twincam ....Not camshaft in this case Car is as left factory and is untouched apart for the belt being replaced by a local mechanic a year or so ago. Noise wasn't there until recent I'll have a mess around under the bonnet with the washing up liquid and see what I can find thanks for your help Live life on the red line |
09-29-2008, 01:32 AM
If it is a vacuum leak, use a lot of soap, as you will need to watch
the exhaust pipe for bubbles ![]() For a vacuum leak you should use "engine start" and spray it around the manifold to see if the idle speed increases. Cheers... jondee86 |
09-29-2008, 09:50 AM
Stig Wrote:sorry for the confusion....need to get my wording right I did wonder why you had just taken out a cam ![]() Make sure to check all your vacuum pipes for severance, the slightest cut on a pipe can cause problems, especially under acceleration. Was it lumpy before the noise developed? |
10-27-2008, 11:13 PM
Tried the soap last weekend....no respose. Looks like I'll have to try some engine start and see if the revs increase
TRD Short Shifter Rattle Noise, It's Normal? | Mattolo | 19 | 20,833 |
04-27-2024 10:04 PM Last Post: banpei |
Clicking noise from glove box | chrisae86 | 4 | 2,273 |
09-08-2022 11:36 PM Last Post: chrisae86 |
Detailed LHD engine bay pictures | Bean | 0 | 3,098 |
08-05-2018 04:09 PM Last Post: Bean |
Noise Insulation for AE86 | decryphe | 1 | 4,217 |
11-03-2016 11:51 AM Last Post: mad.matt |
Whining noise HELP PLEASE | izanagi | 10 | 12,724 |
03-26-2015 06:48 PM Last Post: Komba |
