nzae86's TRD ae86 N2 Race Car Project 2,
09-20-2010, 12:49 AM
Post: #391
NZDMAE86 Wrote:
nzae86 Wrote:
NZDMAE86 Wrote:Great vids, car looks to be pretty settled/gets good grip in the wet, cant wait to see this IRL Smile
Yeah grip was good for the conditions , I was using a Kuhmo V700 tire ,
235 /45/13 rear and a 215/50/13 front and for the amount of water they worked very well ,I was a bit nervous using a tire that I had no idea how it would behave,my other choice was slicks ,and they were a no go in the rain. My Tarmac rally car runs a 205/50/15 Dunlop 03G .These work fantastic wet and dry .
There is still a lot of work to do on the setup of spring rates and shock settings to fine tune for more speed. Driving in those conditions was perfect for learning any bad habits the car may have and to settle in behind the wheel.
Any seat time is a good thing .
Thanks for that info, I was going to ask what tires/sizes you were running. My car is very twitchy in the wet, not 100% sure why tho? I only have 185 60 14 AO48's (rims are only 6" wide) they seem to be very good in the dry, just need to be wider in the rear, lacking a bit of lateral grip back there. I cant wait to get back on the track and play around with the suspension. Good luck with the set up and getting used to the car!
You may want to look at your spring rates in the rear it may be set too stiff ? causing lack of grip , great for drifting but not great for race track or rally type conditions
Your addiction to motorsport can only be cured by poverty !!
09-24-2010, 02:27 AM
Post: #392
Hello, what spring rates do you run? Im running the std 8kg in the front, and 6kg in the back (came on the BC coil overs) Interestingly, I decided at a track day to go out for a bit of a skid/drift, and hardened the rear shocks up a lot, thinking the stiffer it was, the better it would slide, oddly it got more grip in the rear, and made the car understeer? Maybe I've had my shocks/sway bars set to soft for the tires?
09-24-2010, 05:14 AM
Post: #393
Great Job! Thumbs up!
10-05-2010, 10:11 PM
Post: #394
Finally a chance to test in the dry . Still running on wet tires as my second set of rims have not been finished yet , can't wait to get it on slicks.The soft Kuhmo's that I was using were a bit vague after a lap or two in the dry.
I think it sounds not bad!!
http://www.youtube.com/watch?v=dsxdCZYdS1E
10-06-2010, 12:13 AM
Post: #395
Can't wait to see it on slicks Thumbs up! I literally have goose bumps! N2 <3
I really appreciate that you have maintained the original wheel size 13x8/9 rather than succumb to temptation and fit 15" like most N2 in Japan now. Big Grin
I have a set of Kuhmo V70A 195/55R15 fitted on 15x7J (but haven't yet used them for circuit sprints - 3 laps per session) So I'm interested to see how they fare compared to Advan A048R or Toyo R888 that other guys run.
Mine have 4 rows of pattern but now see the V700 has 6 - The "wets" you used are the latter?
[Image: AEU86 AE86 - nzae86's TRD ae86 N2 Race Car  Project 2,] [Image: AEU86 AE86 - nzae86's TRD ae86 N2 Race Car  Project 2,]
I read here http://www.tirerack.com/tires/tires.jsp?...ECSTA+V700
"Important Notice: Kumho Ecsta V700 tires must be shaved to 2-3mm tread depth for any autocross or track use in the dry.
Kumho advises that the Ecsta V700 must be shaved prior to use in dry conditions. If this tire is not shaved, excessive wear may occur causing the tire to wear to the cords prematurely in a localized area.
Tire heat cycling will not prevent the excessive localized wear of full tread depth tires but will continue to enhance tire consistency and wear on shaved tires.
The Ecsta V700 should only be used at full tread depth 5mm for wet track and wet autocross use."
So I guess that these tend to form a thick crust on heat cycling like toasted cheese sandwiches. Tongue
Pity they recommend scrubbing half the tread for optimum dry performance. Confused
RokuSteady : Shakotan - Tsuraichi - Hippari - Onikyan : 神奈川 様式
10-09-2010, 08:35 AM
Post: #396
Kid Karola Wrote:Can't wait to see it on slicks Thumbs up! I literally have goose bumps! N2 <3
Spent the day assembling the second set of rims , decided to go with a gold center this time . Same width and offset as the last set .
So now will have the slicks mounted up as well .I still have a full set of TRD Tosco's that I may end up using on something else as I haven't been able to find any 9" wide ones for the rear.
10-09-2010, 09:27 PM
Post: #397
There have been a few pairs of 9j Tosco's on Yahoo Japan recently. If you go through an agent you can get them no problem.
http://86life.wordpress.com/
10-09-2010, 11:10 PM
Post: #398
I would love to see this car go to Japan and race at N2 AE86 Championship
that would be awesome
Thumbs up!
10-15-2010, 07:46 AM
Post: #399
Kid Karola Wrote:Mine have 4 rows of pattern but now see the V700 has 6 - The "wets" you used are the latter?
Hi the wets that I have are these ,
These are the fronts other than picking up a bit of rubber they look like they have worn not bad at all.So I think for these wheels my alignment setup is in the right direction.Probably with less tread will be less movement and heat build up, but for wet weather the more tread the better.
Now sitting on slicks with the gold look of yesteryear !
The next job is to replace the clutch as the quartermaster twin plate is too severe and getting of the line is almost impossible.Going to replace it with a new Tilton twin plate .
It seems never ending!! Banging head
10-15-2010, 07:59 AM
Post: #400
I had a QM twin plate on my 1UZ turbo build, worst clutch ever. For the power youre putting out, a stock clutch would be easily sufficient, maybe only a slightly heavier cover I would have thought.
  nzae86's AE86 Levin Tarmac rally car build Project 1 nzae86 30 56,862 04-30-2013 07:28 AM
Last Post: nzae86
  my celica race car with race beams Celica RA45 14 21,179 09-14-2011 11:50 AM
Last Post: Celica RA45
  AKR's Daily-driver-race-car asian knight rider 5 10,723 11-01-2009 12:25 AM
Last Post: doggy
  My Project car :D Muchomuchacho 5 6,767 06-05-2008 05:15 PM
Last Post: Muchomuchacho
  A.D.D Performance Demo car (AE86 project) cab32 15 18,009 03-24-2008 03:34 PM
Last Post: cab32
