problem on the chassis ? commun on AE86 ?
09-27-2006, 04:22 PM
Hello ! I detected this on the chassis on my AE86 :
Is it commun on the AE86 ? we told me that yes . I would like to know if that have already happenned to you ? thanks . The car got an accident in the past . :wink: |
09-27-2006, 05:19 PM
it's the accident,dont worry about it
sr86 completed!!........漂うことのマスター!!!! |
09-27-2006, 05:49 PM
That cars not 100% straight, not a problem so as you know about it, an hour on the jig should sort it
09-27-2006, 07:14 PM
Jig ? sorry I m french .
09-27-2006, 08:18 PM
Jig is a thing that allows you to pull and push on the chassis to bend it back into shape
09-27-2006, 08:22 PM
ok I see ! some people told me that just to, I don't know the verb... "to put a little bit of metal to join the two parts" . we told me too that, that arrive when you drive on track on the AE86 . that is why I asked if it's commun
09-27-2006, 08:25 PM
Well a bit of metal would just cover it up, the question is whether your chassis is straight enough, if the chassis is still slightly bent from the accident it can through the alignment of the car of which sucks on the track.
But if you have no troubles with the stability of the car on the track then I guess its fine. Greetz, Bastiaan "mux213" Olij Moved down under, no more hachi |
09-27-2006, 08:32 PM
Ok ! I didn't drive a lot yet . The feeling is weird by I think, it's come from the setup of the rear and front axles wich is not very good . I have to setup it . For example, it's weird . On the front, the car is a lot up (suspension I think) and I have positive camber . there is a lot of think to do on it to setup it well .
09-27-2006, 09:39 PM
Spy, take some pictures, wondering what is installed on the car
09-29-2006, 11:08 AM
2 Spy: go to Tyre shop and check the all 4 wheel aligment ... if it's all OK don't woory about it ...
If it isn't OK, then you have a problem. I have similar thing on my car from some previous accident... but all wheels and aligment are good and straight, and the car doesn't pull on any side on full gas or hard brakeing... Toyota scrap yard car park = AE92GTi - AE82GT - KE30 - KP62 |
New chassis? New chassis! Hype? | decryphe | 19 | 2,082 |
01-16-2025 09:45 AM Last Post: banpei |
4A-GE wiring engine to chassis connectors | Lykowsky | 4 | 7,086 |
06-20-2019 11:38 AM Last Post: Lykowsky |
frame/chassis rails info | Tig | 14 | 21,731 |
12-22-2012 10:38 PM Last Post: Tig |
4agZe problem solved - 99% IC problem | Okami | 41 | 36,407 |
AC problem? Idle problem? | KD2229 | 3 | 4,885 |
08-19-2009 02:08 AM Last Post: KD2229 |
