rear axle half sharft
09-25-2008, 06:22 PM
can any one tell me how can i pull out the half shaft on the rear axle ?
need to check the shaft to see if its bend.... please help. thank you |
09-26-2008, 03:11 AM
any photo?
09-26-2008, 06:50 AM
Use a slide hammer...
Sarcasme is just one of the things I offer Daily driver: '92 Toyota Carina E GTI Rebuilt project: '86 Levin hatch |
09-26-2008, 06:55 AM
Jan Pedersen Wrote:Use a slide hammer... sure ?? some one told me MUST use a hubs puller. |
09-26-2008, 07:10 AM
if its to hard put the wheel back on and put two bolts across each other,and pull the wheel.
It should pull out. unless you still got some bolts on there Cheers |
09-26-2008, 07:13 AM
thanks, it sound ok..
09-26-2008, 03:20 PM
ALWAYS use a axle puller in order to do the job without damaging anything
09-26-2008, 03:44 PM
i've never used an SST when removing rear axles.
the worst thing would be in just damaging the rear axle seal's which cost round $60 Cheers |
09-26-2008, 03:49 PM
JonnyAE86 Wrote:ALWAYS use a axle puller in order to do the job without damaging anything this looks like what i need. now need to find the half shaft than buy the puller . any one have a late half shaft for sale ? thanks guys |
09-26-2008, 04:07 PM
that SST looks like a slide hammer to me. (Top casted thingie on the upper rod in the box)
AE86 rear axle weight | megabob | 11 | 19,130 |
Axle width | totta Crolla | 1 | 1,166 |
Half Shafts Poblem | AlexKTM | 6 | 6,850 |
04-23-2018 04:42 PM Last Post: MIGGZFSU |
Rear axle options | Dino86 | 13 | 13,122 |
Rebuild rear disc brakes toyota crown ms112 axle | bozu | 0 | 3,836 |
