rear axle half sharft
09-25-2008, 06:22 PM
can any one tell me how can i pull out the half shaft on the rear axle ?
need to check the shaft to see if its bend....
please help.
thank you
09-26-2008, 03:11 AM
any photo?
09-26-2008, 06:50 AM
Use a slide hammer...
[Image: AEU86 AE86 - rear axle half sharft]
09-26-2008, 06:55 AM
Jan Pedersen Wrote:Use a slide hammer...
sure ?? some one told me MUST use a hubs puller.
09-26-2008, 07:10 AM
if its to hard put the wheel back on and put two bolts across each other,and pull the wheel.
It should pull out.
unless you still got some bolts on there
Cheers
09-26-2008, 07:13 AM
thanks, it sound ok..
09-26-2008, 03:20 PM
ALWAYS use a axle puller in order to do the job without damaging anything
09-26-2008, 03:44 PM
i've never used an SST when removing rear axles.
the worst thing would be in just damaging the rear axle seal's
which cost round $60
Cheers
09-26-2008, 03:49 PM
JonnyAE86 Wrote:ALWAYS use a axle puller in order to do the job without damaging anything
this looks like what i need. now need to find the half shaft than buy the puller .
any one have a late half shaft for sale ?
thanks guys
09-26-2008, 04:07 PM
that SST looks like a slide hammer to me. (Top casted thingie on the upper rod in the box)
  AE86 rear axle weight megabob 11 19,130 03-29-2024 11:18 AM
Last Post: FanIsHere
  Axle width totta Crolla 1 1,166 10-24-2023 12:20 PM
  Half Shafts Poblem AlexKTM 6 6,850 04-23-2018 04:42 PM
Last Post: MIGGZFSU
  Rear axle options Dino86 13 13,122 01-08-2018 10:19 PM
Last Post: ditn
  Rebuild rear disc brakes toyota crown ms112 axle bozu 0 3,836 12-21-2016 09:37 PM
Last Post: bozu
