removing and replacing speedo wormgear?
08-30-2008, 10:03 PM
I'm having a little trouble removing the speedo unit from my old gearbox to move the wormgear over to my new gearbox. After you remove the bolt that supports it, are you required to give the small housing a good tug with some vise grips or am I doing it wrong?
08-31-2008, 06:23 PM
No one? I've looked through the workshop manual and it doesnt explain anything
08-31-2008, 07:01 PM
You have to get some plyers and then just twist it from side to side while pulling backwards, had the same problem on mine and thats the way to get it out...
AE86 Levin now completed and with new wheels!
[Image: AEU86 AE86 - removing and replacing speedo wormgear?]
Levin renovation post!
Daily driver: VW Golf VI 1,6 TDI Highline, Wife: VW Polo 1,2 TSI Comforline
09-01-2008, 01:32 PM
Use multigrips to give it a gentle twist. Shouldn't take much to come out.
09-03-2008, 05:36 AM
Yeah teh worm gears is a sensitive piece, make sure that you buy the right one.
1987 328ci SR20DET Drift Car
2002 Corolla CE Daily Driver
http://www.TheTunerSource.com
  Replacing Top Windscreen Moulding chrisae86 2 2,000 06-18-2022 08:56 PM
Last Post: chrisae86
  Replacing front lca zenki 6 5,726 05-02-2017 03:23 PM
Last Post: pack
  removing light switch ? (fixed) MC_JP 10 16,669 09-18-2014 05:16 PM
Last Post: MC_JP
  Removing front window trim zenki 7 12,211 09-07-2014 08:36 PM
  Speedo Gear d3nso 6 9,663 04-14-2014 09:56 PM
Last Post: d3nso
