sensor atachment?
07-10-2011, 05:31 PM
sensor atachment?
I´m going to fit my defi gauges soon, but I still need the sensor attachments.
Unfortunatly I cant´t be in my garage until then. That´s why I need your help.Smile I´ve searched, but somehow noone asked before?
What´s the inner diameter of the radiator hose?
I was thinking about ditching the OEM sensor and fit the defi with adapter.
Defis run with 1/8PT, but whats the thread in my block?
I´ve read Toyota pressure senders have 1/8 BSP? is that true?
Anyones knows where to get this adapter?
Thanks Smile
1979 Toyota Corolla KE35
1983 Toyota Corolla AE86
1985 Toyota Corolla AE86
07-10-2011, 09:47 PM
sensor atachment?
radiator hose inner is bout 30 mm
[Image: AEU86 AE86 - sensor atachment?]
toyota MR2/wright off
subaru impreza non turbo/sold
subaru wrx sti type R 320 bhp/sold
88 opel omega/scraped
ford mondeo/scraped
current car 83 AE86 levin turbo
07-12-2011, 04:47 AM
sensor atachment?
Thanks for the answer.
Already ordered the right adapter for it.
Anyone knows the thread of Toyota oil pressure sensors?
07-12-2011, 10:39 AM
sensor atachment?
1/8th NPT is for the oil pressure sensor i think, but don't quote me im not 100% sure, same as the water sensor.
Steve.....this is sparrrrrtan
07-20-2011, 03:32 PM
sensor atachment?
I´ve read that Toyota pressure sensors come with 1/8 BSP a few times, that´s why I ordered an adaptor to see if its true. Smile
Next question, I also got a defi tacho with my gauges, so I need a rpm signal. I was going to connect it to the wire going from the ignitor to the tacho?
Or should I use either IGN or IGF?
Can anybody help? Dumb question
07-23-2011, 10:59 PM
sensor atachment?
Things got pretty difficult!
The defi pressure sensor seems to be a 1/8BSPT and therefore bolts straight to the block!
But this is not confirmed, yet.
Anyone got a clue for the tacho wiring?
07-23-2011, 11:20 PM
sensor atachment?
Look up the DEFI manual for that tacho to find out what type of signal it needs.
Coil(-) usually does the trick, but if it's not built to handle that, you are likely to blow up the electronics.
08-08-2011, 01:48 AM
sensor atachment?
It turned out to be a rare defi oil pressure sender with 1/8" BSP and bolt perfectly to the block. No adaptors required!
But for the tacho wiring, they recomend the tacometer signal and I think that the one of the wires comming from the ignitor (yellow from memory).
I´ll try that and hope is doesn´t get fu**** Smile
08-08-2011, 03:52 AM
sensor atachment?
Actually the Japanese standard PT (Pipe Taper) is the same to BSPT (British Standard Pipe Taper) :wink:
http://mdmetric.com/tech/thddat7.htm#pt
So yes the sensor can be bolt straight up to the block Smile
Usually the most recurrent problem is when you want to fit defi sensor in sandwich plate (most have 1/8 NPT thread)
or
any 1/8 NPT sensor in Japanese plate (like Grex)
08-08-2011, 01:39 PM
sensor atachment?
There we go, couldn´t find any info on a japanese standard PT.Banging head
All the other defi senders are 1/8"NPT, only the oil press senders were also avaliable in BSPT.
I just assumed the´re all NPT, thats why I struggeled an bought adaptors, that are now totally useless... Confused
The Greddy adaptor plate that came with my gauges has a BSPT port, but I´m not sure if its genuine.
  Lambda sensor wiring sam3007 10 4,976 05-23-2022 10:00 PM
Last Post: The Doctor
  AE86 Engine Coolant Temp Sensor izanagi 8 20,905 09-06-2014 05:47 PM
Last Post: izanagi
  Hall sensor totta Crolla 7 8,557 02-28-2014 10:07 AM
  Video : Adjust the TPS (Throttle Pos Sensor) on the 4A-GE Homem Bomba 3 11,460 10-25-2013 05:13 PM
Last Post: Apsogos
  1/8 BSPT adapter for oil pressure sensor Dino86 4 7,330 06-15-2013 12:34 PM
Last Post: S.K.
