sensor atachment?
07-10-2011, 05:31 PM
sensor atachment?
I´m going to fit my defi gauges soon, but I still need the sensor attachments.
Unfortunatly I cant´t be in my garage until then. That´s why I need your help. I´ve searched, but somehow noone asked before? What´s the inner diameter of the radiator hose? I was thinking about ditching the OEM sensor and fit the defi with adapter. Defis run with 1/8PT, but whats the thread in my block? I´ve read Toyota pressure senders have 1/8 BSP? is that true? Anyones knows where to get this adapter? Thanks 1979 Toyota Corolla KE35 1983 Toyota Corolla AE86 1985 Toyota Corolla AE86 |
07-10-2011, 09:47 PM
sensor atachment?
radiator hose inner is bout 30 mm
toyota MR2/wright off subaru impreza non turbo/sold subaru wrx sti type R 320 bhp/sold 88 opel omega/scraped ford mondeo/scraped current car 83 AE86 levin turbo |
07-12-2011, 04:47 AM
sensor atachment?
Thanks for the answer.
Already ordered the right adapter for it. Anyone knows the thread of Toyota oil pressure sensors? 1979 Toyota Corolla KE35 1983 Toyota Corolla AE86 1985 Toyota Corolla AE86 |
07-12-2011, 10:39 AM
sensor atachment?
1/8th NPT is for the oil pressure sensor i think, but don't quote me im not 100% sure, same as the water sensor.
Steve.....this is sparrrrrtan |
07-20-2011, 03:32 PM
sensor atachment?
I´ve read that Toyota pressure sensors come with 1/8 BSP a few times, that´s why I ordered an adaptor to see if its true.
Next question, I also got a defi tacho with my gauges, so I need a rpm signal. I was going to connect it to the wire going from the ignitor to the tacho? Or should I use either IGN or IGF? Can anybody help? 1979 Toyota Corolla KE35 1983 Toyota Corolla AE86 1985 Toyota Corolla AE86 |
07-23-2011, 10:59 PM
sensor atachment?
Things got pretty difficult!
The defi pressure sensor seems to be a 1/8BSPT and therefore bolts straight to the block! But this is not confirmed, yet. Anyone got a clue for the tacho wiring? 1979 Toyota Corolla KE35 1983 Toyota Corolla AE86 1985 Toyota Corolla AE86 |
07-23-2011, 11:20 PM
sensor atachment?
Look up the DEFI manual for that tacho to find out what type of signal it needs.
Coil(-) usually does the trick, but if it's not built to handle that, you are likely to blow up the electronics. FABRICA MI DIEM, PVNC! |
08-08-2011, 01:48 AM
sensor atachment?
It turned out to be a rare defi oil pressure sender with 1/8" BSP and bolt perfectly to the block. No adaptors required!
But for the tacho wiring, they recomend the tacometer signal and I think that the one of the wires comming from the ignitor (yellow from memory). I´ll try that and hope is doesn´t get fu**** 1979 Toyota Corolla KE35 1983 Toyota Corolla AE86 1985 Toyota Corolla AE86 |
08-08-2011, 03:52 AM
sensor atachment?
Actually the Japanese standard PT (Pipe Taper) is the same to BSPT (British Standard Pipe Taper) :wink:
http://mdmetric.com/tech/thddat7.htm#pt So yes the sensor can be bolt straight up to the block Usually the most recurrent problem is when you want to fit defi sensor in sandwich plate (most have 1/8 NPT thread) or any 1/8 NPT sensor in Japanese plate (like Grex) |
08-08-2011, 01:39 PM
sensor atachment?
There we go, couldn´t find any info on a japanese standard PT.
All the other defi senders are 1/8"NPT, only the oil press senders were also avaliable in BSPT. I just assumed the´re all NPT, thats why I struggeled an bought adaptors, that are now totally useless... The Greddy adaptor plate that came with my gauges has a BSPT port, but I´m not sure if its genuine. 1979 Toyota Corolla KE35 1983 Toyota Corolla AE86 1985 Toyota Corolla AE86 |
Lambda sensor wiring | sam3007 | 10 | 4,275 |
AE86 Engine Coolant Temp Sensor | izanagi | 8 | 20,266 |
09-06-2014 05:47 PM Last Post: izanagi |
Hall sensor | totta Crolla | 7 | 8,244 |
02-28-2014 10:07 AM Last Post: Ivan141 |
Video : Adjust the TPS (Throttle Pos Sensor) on the 4A-GE | Homem Bomba | 3 | 10,886 |
10-25-2013 05:13 PM Last Post: Apsogos |
1/8 BSPT adapter for oil pressure sensor | Dino86 | 4 | 7,002 |
06-15-2013 12:34 PM Last Post: S.K. |
