sensor atachment?
08-08-2011, 08:41 PM
sensor atachment?
Defi is always PT !!
It look like NPT but the thread is different ! You can take a look on Defi manual: http://www.nippon-seiki.co.jp/defi/media...1003-2.pdf Or in the Defi catalog: http://www.defi-shop.com/catalog/defi_ca...2011_e.pdf Quote:/!\ Sensor attachements (1/8PT) are necessary to install oil press, And yes, greddy (grex) is also PT (BSPT if you prefer) |
08-08-2011, 10:15 PM
sensor atachment?
Damn, I thought I got it all figured out!!!
Already spend days for researching... I found this: http://www.defi-shop.com/product/meter/m...html#turbo But on a 2nd look, it´s imperial gauges only!!! If you look for the Greddy adatorplate on the internet it says they got NPT (27 threads/inch), but these are US pages, too. My defi set came off a JDM RX7 so the JDM Greddy plate seems to have BSPT as standard. Man that´s confusing... I wish those manufactures just stamp the type of thread somewere on the senders and adaptorplates!!! Well, I guess the only problem is the water temperatur, cause the adapter I bought is NPT. 1979 Toyota Corolla KE35 1983 Toyota Corolla AE86 1985 Toyota Corolla AE86 |
08-09-2011, 12:44 AM
sensor atachment?
Personally I use small adapters to fit my NPT senders on my block and my Grex plate (bought in japan)
I also have a thread gauge and tap (both 1/8 PT and NPT), it help a lot to be sure what kind of thread it is |
Lambda sensor wiring | sam3007 | 10 | 4,262 |
AE86 Engine Coolant Temp Sensor | izanagi | 8 | 20,233 |
09-06-2014 05:47 PM Last Post: izanagi |
Hall sensor | totta Crolla | 7 | 8,235 |
02-28-2014 10:07 AM Last Post: Ivan141 |
Video : Adjust the TPS (Throttle Pos Sensor) on the 4A-GE | Homem Bomba | 3 | 10,862 |
10-25-2013 05:13 PM Last Post: Apsogos |
1/8 BSPT adapter for oil pressure sensor | Dino86 | 4 | 6,998 |
06-15-2013 12:34 PM Last Post: S.K. |
