shock question
09-12-2009, 09:32 AM
shock question
can i use a cressida shock in place of my stock ae86 shock?
09-12-2009, 10:48 AM
shock question
You can, but you'll need a small spacer as it is slightly shorter.
09-12-2009, 11:52 AM
shock question
sweet. i got them for free. is there and advantage to using cressida shocks?
09-12-2009, 12:32 PM
shock question
Perhaps the fact that they are shorter might also mean they have a shorter shaft. This would be an advantage over full length shocks when you're lowering. Cant remember the exact difference anymore.
The difference in the insert bodies for the front is no more than about 1-1.5 cm's.
Afaik the cressida is a heavier car, especially in the front, so there's also a good chance that the valving is a bit better suited to higher springrates.
I have a pair of red Koni's for a cressida that I base these remarks on. Bought them for 10 euro's years ago (hurray for ebay). They will be going on my bro's KE25 in AE86 struts.
  Coilover shock replacement phill 92 9 11,398 08-28-2012 08:46 PM
Last Post: phill 92
  Maybe problem with TRD shock absorber and springs Mattolo 22 20,290 10-15-2011 07:40 PM
Last Post: zenki
  Damper/shock absorber forces Ozone 15 23,434 03-29-2010 10:47 PM
Last Post: Ozone
  Ke70/Ae71 rear upper shock mount inner panelthe same as AE86 adamsaiyad 1 4,136 01-20-2010 10:21 PM
Last Post: adamsaiyad
  TRD rear shock absorbers AE86 DRFT 2 4,185 12-10-2009 10:17 AM
Last Post: NoHachi
