time for changing my transmission
01-23-2006, 12:16 PM
I've got a t50 lying in my (bed)room and want this into my celica.
How much time is it to replace the t50??
I've got now a t40 in it and want to upgrade to the t50..
no changing pressure plate or something, just the t50.
How long does it takes for first-timers (2 persons, at friday morning)
thanks Mark
[topic title edited by ivan]
01-23-2006, 01:20 PM
I don't know about first-timers, but an expert me3chanic will need at least 2 hrs. If it was me (super first-timer), I would be ready to work until the afternoon and possibly not even finish. Make shure you have all gaskets, bearings and oil before you start. Good luck!
01-23-2006, 09:38 PM
To change my T50 on my AE86, on a ramp, takes less than an hour easy! But then i do work for Toyota and it is 2nd nature to me! Big Grin
[Image: AEU86 AE86 - time for changing my transmission]
01-24-2006, 10:08 AM
And I'm a student, but willing to go to the DIY garage.
Will it takes more then 3 or 4 hours??
Mark
01-24-2006, 09:21 PM
It's easy to change these gearboxes, I just did a quick count up and reckon there are about 26 bolts (mostly 12 & 14mm spanner size)) to remove/replace none are awkward even without a ramp, just make sure the car is well supported. I use the drive on style ramps for the front wheels and axle stands on the axle. A small tip: if you have help get them to support the gearbox with rope from inside the car ( through tranny tunnel) when lifting in/out. If no help available just support 'box on a decent sized trolley jack and lift into position with this.
Fill with oil through the gearstick hole but use a tiny funnel to access the small hole.
Don't overtighten the clutch slave cylinder bolts. Loctite bolts that have non removable lock washers. Use new lock washers for propshaft bolts. There will be quite a lot of oil still in the box even after draining so try to keep it as level as possible when lifting in/out.
Allow 4 hours
That's about it, good luck Smile
  Gearbox mount and transmission mount gh0st 9 3,916 05-08-2022 03:28 PM
Last Post: totta Crolla
  Changing distributor when carb 4age izanagi 14 16,149 07-04-2016 03:27 PM
Last Post: Uzelac
  axle swap time how capable is a std crownwheel and pinion fax0815 32 48,025 09-26-2013 08:33 PM
Last Post: Lajoosh
  HELP!!! hard time starting drift 36 34,290 04-23-2012 01:40 AM
Last Post: drift
  Changing propshaft bearing. Anything I need to know? Lauren 5 9,049 04-15-2012 02:12 AM
Last Post: krullibull
